Question about Intel D525MW Innovation Series Motherboard with Dual-Core Atom D525 Processor and NM10 E...
Vista 32bit new install crashes are windows update. using correct and uptodate drivers? what update could it be?
  • Intel Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on May 26, 2011
Could not find audio drivers for windows xp 64 bit
you should be able to install the 32bit driver normally.
go to device manager and click on update driver once their point towards your 32bit driver
Jan 17, 2014 | IBM ThinkCentre Computers & Internet
Hi, I have a Canoscan 9900F. I have a problem when installing it on a new Windows 7. Do you have any new driver for my scanner? My name is Joga, I live in Indonesia Thanks
i have the same problem with this scanner
but you cannot do any thing Joga
problem is windows 7
i have both of Windows 7 (64bit) and Visa (32bit)
and use Vista when i want to use scanner
you can buy a new scanner to solve this problem with windows 7!
Drivers only available for Windows XP (32bit) and Vista (32bit):
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_9900f#DriversAndSoftware
Oct 24, 2010 | Canon CanoScan 9900F
I installed windows 7 in my laptop and while installing the audio drivers its an failure how can i install the realtech audio drivers to my machine?
Hi you can try finding out what your sound card is or by going to your manufactuars website and finding it there by looking under your make and model or you could find out yourself and download it from the internet.
I hope this helps
Carl Redding
Jul 18, 2010 | Lenovo 3000 Y410 Laptop
How to install lenovo web cam
before you install webcam driver make sure camera is on, you can check it by pressing FN + ESC key, then once enable, try installing/upgrading driver
Jun 16, 2010 | Lenovo 3000 Y410 Notebook
Tried to update drivers for acer arcde deluxe, system crashed and now the arcade won't start at all. Unable to update again.
Do a windows system restore to a day before you installed the new software, and if this fixes it, leave the acer arcade alone. If you must upgrade acer arcade, check the acer website and be sure you get the correct version for your version of windows: ie xp/vista and 32bit/64bit.
you can check your windows version this way: right-click 'my computer' in xp 'computer' in vista and left click properties. this will tell you your windows version, and whether it is 32 or 64 bit. If this fails again, do another system restore, and contact acer for support. My best advice is to leave it alone if you get the pc functioning properly though. please contact me if you need any further help.
Jul 19, 2009 | Acer Aspire 5720-6661 Notebook PC
System crashes and i have to reformat after installing msn premium software on new 64 bit vista laptop
you can downgrade to 32bit. you would have to reinstall windows using a 32bit cd. i would recommend it you wont see much of a difference. all programs where originally made for 32 bit. the only difference between the two is that 64bit supports more ram. like xp pro; 32bit will recognize 3.25gb as ram even if you have 4gb installed but other than that not much difference. personally i dont like any 64bit systems nor vista... but with 32bit you will be able to run a wider range of programs with no problem
Apr 16, 2009 | Computers & Internet
DVD
what operating system did you replace XP 32bit, XP 64bit? Was the version of Vista you used the 32bit or the 64bit. You may need to go to HP.Com and look for replacement drivers for the DVD. You can also use the windows update to obtain correct drivers for the DVD if they have tested them already. Another option is to go to the manufacturer of the DVD device and see what they list for the driver. Just remember there is a big differance between the 32bit and 64bit drivers. Read on the Vista system you installed and see what level was installed in your system. Regards, rcampsr
Feb 21, 2009 | HP Compaq Business Desktop d330
When i use vista & listen any song then it get hang and shows
Do you install a driver from CD that comes with your Motherboard? Vista CD/DVD Driver Pact creates such problem. For Vista drivers you can directly download from internet (The best Drivers/uptodate)
When you connect to internet Windows Update will automaticly download the drivers!
Best Luck!
Jan 23, 2009 | ASUS P5PE-VM Motherboard
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
Intel D525MW Innovation Series Motherboard with Dual-Core  Atom D525 Processor and  NM10 E... Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
