Question about Amana Dryers
I have amana distinctions dryer thats 10 years old it runs so hot its hard to take the cloths out when done
  • Amana Master
  • 7,482 Answers
Hi dionwheels62
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
Posted on May 26, 2011
My dryer is overheating. Clothes are so hot you can't handle them. Amana electric model LEA60AW
You control thermostat is not working. Replace it. It mounts on the blower housing. After making sure the blower is not loose replace the stat. It is the only thing that controls the temp. The limits shut down the element if the control stat fails to do so. Them clothes is getting too hot because the 250f limit on the element is shutting down the element. The fuse is not blowing because it is rated for 350f. Therefore with the control stat inoperable the clothes is getting too hot.
Apr 10, 2013 | Amana Dryers
3 year old Amana NED 7200 dryer has film of black grease in drum back portion and grease is on clothes after coming out of dryer.
Check the thermostats for continuity. Sounds like the dryer is getting to hot and may have melted something. There is nothing with grease in that area of the dryer,
Nov 06, 2012 | Amana NED7200TW Electric Dryer
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Dryer tub doesn't spin - motor runs and hot air comes into the tub area but the tub itself has quit spinning. Could this be the belt since the motor is running and the dryer is heating up? This is an...
Unfortunately you will have to search for thebelt with auto stores to see if any of the models will match. Check to see if any machine spares shops can help, get intouch with industriaal spares outlets to help you.
Sep 23, 2010 | Amana DLE330RAW Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
I purchased an Amana drier a few years ago and my aunt purchased the exact drier the model #ALE331RAW It heats so hot you can not hardly touch the cloths
too hot??? thas gerenally a sign of insuffecient venting, check for arestricted and/or blocked vent. it cant release the proper amount of heat and its buildingup inhte machine
Mar 07, 2009 | Amana DLE330RAW Electric Dryer
Amana Distinctions Dryer Runs for a while and then stops before clothes are dry
YOUR MTR IS GOING BAD PUT IN YOUR BUDGET TO REPLACE THE DR ASAP
May 29, 2008 | Dryers
Amana dryer problem
Ok " replace the electric motor
Jan 21, 2008 | Dryers
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Dryers Logo
85 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
