Question about Bissell 8975 CleanView Bagless Upright Vacuum
How do i put the plastic bagless part back - Bissell 8975 CleanView Bagless Upright Vacuum
  • Cathann Smith May 26, 2011
    What plastic part? Do you mean the plastic part the hold the dirt, hair etc or the plastic part for the filter or both? I have Cleanview Helix which has a a dirt container and filter cup and a lock'n seal lever. If your vacuum is the same then I have a solution!
    Problem Solver:
  • 19 Answers
I have an Bissel Cleanview Helix which I think is similar. The lock'n seal lever has to be in the unlock position first. Place the filter cup in first and then the Dirt container next and hold it in place and move the lock'seal lever to the lock position. I hope that this has helped you.
Posted on May 26, 2011
Hoover Supreme wind tunnel upright model. I have a bad on-off switch. How do I replace it?
Take the two screw off the handle and then remove the upper handle devise. This will expose the real on/off switch which is on the top of the unit. There is a plastic actuator that rubs up against the switch when slide the plastic switch on the handle. What happens is the plastic wears out and does not make good contact with the real switch.
A simple solution is to wrap duct tape around the plastic actuator to make it thicker, which then makes more contact with the real switch. Put the cover back on with the two screws on the back. Slide the plastic on/off switch an it will turn on and off again!
Nov 15, 2010 | Hoover U6630-900 WindTunnel Bagless...
The switch on and off wont work so i took it off and it works but know iam having problems putting it back together the spring are the problem
Those springs are tricky to get back in. you can use the flat end of a screwdriver to hold them down and compress them. I would recomend taking it to a proffesional to get it put back together right before you break the plastic and cost yourself some big money.
Oct 03, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vac is smoking and not sucking
eazy turn it upside down open the bottom take the plastic cover off check the band change it or take all the hair off put it back before u put it back get wire hanger and check the hole were it sucks carfully stick the hanger in their with the fron of the hanger bend like hook so it could take watever stuck in the tube and clear the pass of sucktion tat shud solve ur problem
Mar 15, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
In need of a picture of the on/off switch for Dyson DC17.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Feb 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar won't turn--belt still but off of shaft
there is a reset button under the handle its gray and has a brush pic by it this should rest it.
and as far as puting the belt back on try going from the bottum plate it should just unscrew the four to six screws and pull it off hope this helps
Jan 17, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Filters
Okay simple. You should have 3 filters. A foam, plastic and a round paperish filter. Foam filter goes around black air filter which goes in the bottom removable tank and then the grey one goes in the upper tank and twists in
Dec 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Bissell Powerforce bagless 6594 W filter cleaning and reassembly
the sponge filter goes around the plastic part with tons of vertical slits on it
Aug 08, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell 8975 CleanView Bagless Upright Vacuum Logo
79 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
