Question about Sunbeam SCA103RWB1 Room Air Conditioner
Sunbeam A/c 10000 BTU displays EE in LED which suggests that it is getting power but does nothing. Any help would be appreciated.
  • 2 more comments
  • smholbrook71 May 26, 2011
    The filter is brand new, and clean. Any other suggestions? Thanks.
    The Filter is brand new, and clean.
    the "reset" breaker on the units plug works fine.
  • 17,970 Answers
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into.
If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance, but it is still completely dead there may be a problem in one or more of the following areas:
  • Wiring (Inspect for any broken or burnt wiring)
  • Thermostat
  • Compressor
  • Overload and/or relay
  • Selector switch
  • Control board
Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
I could think it has something to do with the temp sense circuit of the control board; in other cases
that says the same error, and if bypassed the temp sensing bulb with a resistor the unit will run but they don't have any way of controlling the temp. If this work, try to find out that type of thermistor part.
Keep us updated.
Posted on May 26, 2011
    Genius:
  • Sunbeam Master
  • 1,033 Answers
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Thermostat Compressor Overload and/or relay Selector switch Control board
  • Robert May 26, 2011
    If you are getting power to the control board but no power out of the control board then that board is bad.
    Do you have a multimeter to check some components? If you dont then it's difgicult to tell you exactly whats wrong with the unit. It will fall it the components that I posted but you need a meter to check those components.
  • 4,323 Answers
Hi
EE error reminds you to clean the filter, to clean it turn the unit off and unplug it, then clean the filter completely. After cleaning if the issue returns then replace the filter. Hope this helps...please post back for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott May 26, 2011
    Good if you have cleaned the error code. This EE means thermistor failure or thermistor fault and should be replaced
  • Daniel Scott
    My assistance is refused.....anyways I told you it is the thermistor that is bad and should be replaced
HOW TO FIX ?
If you are getting no indicators on the projector then you need to replace the power supply or the fuse on the power supply
Dec 16, 2014 | BenQ W5000 1080p 1200 ANSI 10000:1 DLP...
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
I have the 30xa and when i type in exponents and use the ee key it gives me th wrong value. for ex if I type in 10 EE 3 it gives me 10000 instead of 1000.
10EE3 is supposed to be 10000. 10EE3 is 10 times 10 to the third, which is 10 to the fourth. If you want 1 times 10 to the third, enter it as 1 EE 3, which will give you 1000.
Feb 11, 2011 | Texas Instruments TI-30XA Calculator
Air conditioner won't turn on. Showing EE on the LED
hello. i can help you.
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
  • Thermostat
  • Compressor
  • Selector switch
  • Control board
Jun 08, 2009 | Sunbeam SCA103RWB1 Room Air Conditioner
No Signs of Life
If it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free or you may have to return it to the dealer.
GE Customer Service is here.
Usually they will go by the date on the tag on the oven to determine warranty.
Feb 04, 2009 | GE JES1358 Microwave Oven
ASUS P5P800-VM motherboard - LED on; fan on; no monitor output
if it has an external video card reseat it or clean the gold contacts
Nov 06, 2008 | ASUS P5P800-VM Motherboard
EE Flashing in the in the humidity LED indicator
Hello rich784,
Welcome,
You said, unit is working but I'm not getting a % read out in the LED indicator, so I can not tell what the humidity is in the unit.
I called Haier and I got nothing but a big run-around
Let me see if I can help!
1.Turn the unit off.
2. Pull the plug out.
3.wait 5 minutes with the plug out!
4.plug back in after at least 5 minutes.
This reboot should have cleared your EE code and reset you system !
Because the unit still runs and is cold, this told me you may have a glitch in the electronic system.
Let me know how it goes.
I'm hopeful this is solved!
Thank you for using us,Huuum
I am waiting for your response.
Please remember to leave a rating!
Oct 21, 2008 | Haier HVR042 Wine Cooler
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Sunbeam SCA103RWB1 Room Air Conditioner Logo
118 people viewed this question
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
