Question about Garden
I have a sumec linhai sv150 petrol lawnmower engine. Everything runs ok on the mower for about 5 mins, then the carb starts to flood and all of the petrol from the tank leaks out onto the mower casing. I have cleaned the carb out, but the problem keeps happening. Can you advise me how to fix the problem and where I can find a manual.
boscia
  • 163 Answers
SOURCE: Lawn Mower leaks petrol
it might be for a missing hose to a primer bulb or return line to the tank. does it seem like either are missing?
Posted on Nov 29, 2008
KMusselmann
  • 247 Answers
SOURCE: Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Posted on Mar 20, 2009
SOURCE: flooding carb
the fuel lines were hooked up backwards thanks
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Posted on Apr 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: nannie what can be wrong with my power devil
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Posted on Jun 23, 2009
Lawnmower leaks fuel from carb
It sounds as though your float and needle are stuck open or not closing properly, thus flooding with fuel. However it is hard to give exact fix/problem without a model number of the engine to be able to see the specs and design of the carb.
Aug 27, 2014 | Garden
How to fix lawnmower
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Aug 16, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I bought an ariens 932027 ST724 W/ 7HP Tecumseh HSK70 130266S Engine. It seems to have a problem running for longer period of time than 5 or 10 min. after that it starts back firing and shuts down. It will...
Almost certain, having had this problem with this mower several times, that your petrol cap which is suposed to let air into the tank does not. after a few mins of running suction develops and the engine stops. you check the fuel level and its ok so you restart and it goes fine for another 5 min. by removing the petrol cap you let air in and temporarily fixed it. Clean out the arangement of screws and springs and filters under the fuel cap.
Dec 28, 2010 | Sport & Outdoor - Others
How do you tune the carb on a honda hr194 petrol lawnmower
most carbs just need to be rebuilt it's not a hard job but when your finished adjust the mixture screw out 1 full turn of the screwdriver. that will get it started then fine tune it from there....good luck
Apr 04, 2010 | Garden
RZT 50 Floods /had carb. serviced 4 times -runs 5 mins to 1hr before it stalls /have to drain carb.bowl let sit for several min. before it will start. Kawasaki FH661v-AS05-R engine
Sounds like you are in a hot weather if so it may be the vent in top of the fuel cap. In the hot the pluged hole lets the gas tank build up pressure forcing fuel by the needle valve causing fluding in the carb.
Aug 27, 2009 | Garden
Valve spring broke
Not sure but I think someone told me it is a knock off of the Honda? If so maybe try comparing? Ck size, Spring tension & etc?
I know not much help but that's where I'd start. Been told by a local small eng shop there aren't internal parts available for the Sumec engines.
Mike
Dec 09, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Garden Logo
985 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
