Question about Acer Aspire One PC Notebook
Stuck on "Preparing to configure
  • cgentile769 May 26, 2011
    Can I just remove the battery?
    None of the buttons work. It's frozen on that screen.
  • 639 Answers
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications.
right click on each application and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22 39_4-10322935.html ), and it has good ratings, but I have not personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
Posted on May 26, 2011
  • Avishek Samaddar
    Avishek Samaddar May 26, 2011
    Not recomended but you can hard press the Power ON button for 30 Secs to switch it off.
  • Avishek Samaddar
    Then remove the battery and perform a restart
The computer is stuck on preparing automatic repair
use the operating system/install boot from it, then run repair the computer form the install menu
May 29, 2017 | Power Computers & Internet
Acer stuck on preparing to stand by
I would force power off, (press and hold down the power button) then start up windows and download any updates that are missing and then use the Shut Down command instead of the Stand By/Sleep mode.
Sep 11, 2014 | Computers & Internet
Toshiba Satellite stuck on Preparing to configure Windows screen?
Unplug, remove battery, leave battery out, plug in, reboot, select Normal boot. post results
Feb 26, 2013 | Toshiba Satellite U925t
Get out of safe mode
if you cant turn it of try shutting it down from command prompt
press windows key+r t
when the run box apears type CMD and press enter
type the following command without quotes "shutdown -s" then press enter and it should shut the computer down, if your computer goes back into safe mode when rebooting turn it off then back on and keep pressing the F8 key until a dialog with text comes up, use your arrow keys and navigate down to the last known good configuration box and hit enter it should work
Dec 17, 2012 | HP Compaq 6735s Notebook
First time start up error message
indicates a problem hard drive not allowing the boot up to complete
take it to a computer repair shop for a proper diagnosis
Apr 24, 2017 | Fujitsu LifeBook AH531
Hey, someone please help me. I have an issue with my PC. this is what happened. My PC, an IBM ThinkCentre, running on Windows XP, used to give trouble in loading got stuck. My friend recommended that I...
I posted the previous solution :)
You can name your machine what ever you like I would keep it simple and not include spaces to avoid confusion. The last machine I rebuilt I named after my dog "Ollie".
Mar 15, 2011 | Computers & Internet
Hi! Computer screen froze when shutting down, I turned it off, turned it back on and now it is stuck on "start up repair" screen, for hours! Help!
Restart it and try start windows normally.
If that doesn't work, try safe mode and restart the computer.
Nov 20, 2010 | Computers & Internet
My Acer One Aspire is stuck in hibernate. After it updated itself and said it was preparing to shut down, it was stuck in the preparing for shut down mode for hours. When I let the battery run down to turn...
This solution may sound stupid, but it is affective. Try to press really long time (about 1-2 minutes) on the power button of the laptop. wait for it to shut down completely. Then turn it on to see what happens.
What may have caused this is an update of any sort.
Nov 11, 2009 | Acer Aspire One PC Notebook
Preparing to hibernate
Hold down the power button until the computer shuts off completely. That should solve your problem.
Feb 19, 2009 | HP Pavilion dv1000 Notebook
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Acer Aspire One  PC Notebook Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
