Question about Philips 9P5544C 55" Rear Projection Television
Ptv843 phillips magnavox color problems 64 in.
I have problems with green light around white colored objects wondering how much it would cost to have it fixed
[email protected]
  • mattsingle Aug 17, 2008
    Is there no way that it could be the coolant for the green color? Just wondering?
  • jeremymacho Oct 03, 2008
    I have bright blue and green halow around things that are supposed to be light colors. The faces are red though.
  • 1,800 Answers
Its u need a convergence tube replacing ask one of aour repairman by typing ur zip code!! rate me as fix ya!! plz
Posted on Aug 16, 2008
  • Jalal Sordo
    Jalal Sordo Aug 17, 2008
    yes its might be the green picture tube!!
6ya staff
SOURCE:
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
7P5441 C101 54in color is wrong
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
White glow around dark objects
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 28, 2010 | Philips 55PW9383 55" Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
The words blare green around them.
revise la convergencia de su tv iy los anillos del cañon
Aug 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear projecton model fp4640w104 color os off and alittle fuzzy.how can I fix it??
change the coolant in the CRTs. Its avery common problem with that model. The color gets dim hard to focus and often you will see halos around objects. You can get the Phillips CRT coolant replacement kit at the following link which contains the coolant and step by step instructions on CD that shows how to do the replacement. Heres the link.
http://servicemanuals.vstore.ca/
Jan 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
Screen is getting darker
The most likely cause is the blue and green tubes need to have the cooling fluid changed. After many years the blue and green get clouded with algae. The red tube won't have the problem due to the red spectrum kills the algae before it has time to grow.
The way to replace the fluid for is to completely remove each CRT from the set, remove the drain plug, drain the fluid out the tube, disassemble the lens, give it a good cleaning; then reassemble; add fluid; and reinstall in set. If you check with the site www.TvRepairKits.com they are working on a kit that includes the fluid and photo instruction guide.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV repair
you need to replace the coolant in the CRTs ( picture Tubes) you can get the repair kit at the following link which contains all the coolanr and the instruction CD with the step by step instructions with pictures so you can easially do it yourself. Heres the link.
Aug 17, 2008 | Philips 9P5544C 55" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Philips 9P5544C 55" Rear Projection Television Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
