Question about Bosch 125BO NG AquaStar Outdoor Natural Gas Tankless Water Heater
The water goes cold after 40sec, have to turn water off and on to get hot water again. Not sure if this is the right model but it looks the same and doesnt have any electricity, 16H natural gas. regards Nicholas Maynor
  • Anonymous Mar 26, 2014
    turn the warm water on and it starts to get warm I electric no gas the lite comes on I have flipped the breakers and still the same thing
Before calling service technician, open following link for Bosch troubleshooting resources
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
The model and serial number are usually located on label on side or front of unit.
Link above might have your manual where you can read advisories and required maintenance.
If you are not getting error code, then problem could be plumbing related, but this is a shot in the dark, and one of many places to start troubleshooting.
http://waterheatertimer.org/Crossover.html
Error codes are starting points, and a problem on one tankless can have entirely different cause and solution than same error code on another tankless.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 26, 2011
  • Anonymous Jun 01, 2011
    You asked for do-it-yourself help without giving model number or saying what you've done so far to fix problem. If the 100% researched answer is not helpful, then next time take advantage of fixya assistance live and pay expert to ask what model number you have and what you've done so far to fix problem.
Radiators hot no hot water. Luke warm for a bit. Then back cold. Setting is past 'eco' just moved in not used to combi but surely this isn't right
check the diverter valve. look to see if when hot water turned on the small electrical switch at the end operates. If not then a ned valve or diaphragm
Apr 10, 2015 | Water Heaters
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 17, 2014 | Water Heaters
Rheem warrior 40 gal warrior
You could start by seeing if the thermostat is wide open. Sounds like it is on low or vacay mode. How far is the run between your heater and the bathing area. Might need to insualet some piping.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2013 | Water Heaters
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
GAs will not shut off when water is turned off. We already bought and replace the water valve. If we turn off the hot water, it makes a terrible sound and overheats. It eventually goes to the emergency...
Turn Hot Temperature down lowerthan current setting. Make sure that Heater operates properly before using. A defective temp sensor can SCALD and BURN. What TYPE of Terrible SOUND? Do you have anyone tht is the least bit mechanical to observe and direct you to the right source. IF your husband enjoys cold showers this sounds like an opportunity to suggest that with WARM baths the two of you can have some Peaceful time! And both come out clean!
Aug 25, 2010 | Bosch Water Heaters
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
Problem with hot water flowing from cold outlet
The hot and cold pipes run in the wall next to one another. So the water turns cold again as soon as the water starts flowing
Jun 16, 2009 | Honeywell Water Heaters
Water heats for about 3 seconds and goes cold
Take the cover off and look for reset that has trip.If you can't find no reset turn the power off and wait for five minutes,turn on and turn water on also to see if you get hot water.
Mar 14, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Bosch 125BO NG AquaStar Outdoor Natural Gas Tankless Water Heater Logo
502 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
