Question about Olympus Cameras
My camera takes 3 pictures instead of 1, - Olympus Cameras
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 111 Answers
What you are on is sometimes called "Burst" mode. It is meant to be taking pictures of things like baseball players, so you can get the shot right were he hits the ball. I am not a owner of an olympus camera, but look through your cameras settings, and try to find that setting and switch to "single".
Look in your manuel for more detailed instructions.
Posted on May 26, 2011
My camera keeps taking multiple shots instead of just one!!
Try pressing the burst mode button between the shutter release button and the mail mode dial.
25577250-m1vkig3zsqigira5v5ftz33l-4-0.png button 18
Mar 16, 2015 | Panasonic Lumix DMC-FZ100 Digital Camera
I can no longer download pictures from my camera to my computer. I reinstalled the software and still cannot download the pictures. Thanks for your assistance.
Possible solutions in order for downloading pictures to the computer issue:
Remember you need to turn the camera on when transferring.
Instead of using the Easy Share Programe
1: Go into my documents
2: Find the location of the camera and your pictures
3 Drag and drop from the camera to the computer
Try a different USB outlet
Try a different cable
Try a different computer.
Dec 17, 2009 | Kodak EasyShare One Digital Camera
I have a sanyo camera 7.1 mega pink and everytime i try and take a picture my screen goes black and shuts off without the camera piece going back in! I have almost the same problem except when I take a...
In the first case, if the camera turns off by itself with lens not retracting, try fresh alkaline battery. If that does not work, then the ribbon cable from battery charger to mainboard inside the camera is probably causing the problem.
An internal contact can also cause same problem.
If instead pictures are completely black, then there are several possible reasons:
1 There is a setting problem, remove and put back batteries to fix the problem.
2 The camera curtain is stuck and it is not opening.
3 The CCD sensor is faulty, more likely the ccd sensor contacts are broken.
4 The lens assembly has an internal problem.
Apart situation 1 , in all the remaining cases the camera will need repair.
Regards.
Jun 01, 2009 | Sanyo VPC-S880 Digital Camera
Camera takes 3 pics instaed of 1
Power up camera, press Menu >> Initialize >> OK
Provide date and time upon rebooting camera.
This will solve your problem.
May 14, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
TAKING PICTURE TO SLOW
Here are some tips to make your camera faster. 1- Decrease picture resolution when you do not need that much resolution. The highest resolution have a big load of data to write, taking some time. 2- Turn off flash when possible. Every flash unit needs some time to charge and this can be time consuming. 3- The camera can take some time autofocusing. Press halfway the shutter until the camera locks its focus, than press the shutter all the way. This will help you to take even better pictures. Good luck!
Nov 22, 2008 | Vivitar VIVICAM 8625 Digital Camera
My Sony Cyber-shot DSC-W100 and picture "tiling"
You may be accidentally changing the menu setting from normal to multiburst.
Aug 19, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Cybershot dsc s700
Burst mode is set in the Menu of the camera. Then press left arrow instead of right arrow. You will see normal or burst mode. Select normal mode. Hope this helps.
Thanks
Mar 26, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Camera Won't Take Pictures!
you camera is just set to burst burst mode is taking multiple pictures in a single shot.
1.turn on yer camera
2. press the menu button
3. select mode (rec mode)
4.select normal instead of burst
5. select OK for every ptompt
pls reply if it worked
avaya ****
maimai alovera
Jan 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
How to change the ISO
Changing the ISO is only a patch for the problem - although it will allow you to take pictures with a faster shutter speed (which will help with motion blur) it's not panacea - it will add significant noise to the photo
I'd advise instead on of the following:
1) Place the camera on a tripod or other sturdy surface (like a desk)
2) Use more light (or, better still, use the flash if your subject is close)
3) Use the self-timer - a lot of camera shake originates from the movement of the finger on the shutter button
If you still want to change the ISO, check the camera manual (not all cameras allow you to change the ISO)
Dec 20, 2007 | Cameras
Cameras Logo
41 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
