Question about ASUS Socket7 Bios:0202 R:3.10Motherboard (PIP55T2P4)
Bios problem When I power up and hit the delete key the bios screen comes up but will not accept input from the key board (PS2). I have tried a different keyboard (USB) but no better. \ Has the bios failed ? Should I reset the bios, and how would I do this? How do I remove the bios battery? Thanks Graham
  • pyrex 77 Aug 17, 2008
    The bios is set up for a USB keyboard, and because I can , by pressing Delete get the bios set-up screen, I don't think its anything to do with the keyboard.
    I'll try taking out the bios battery, and see what happens
  • Ranjeet09 Jan 30, 2009
    i have bios problem
  • 781 Answers
Try another PS2 keyboard as your BIOS may not be set to recognize usb on boot up I had same problem until I enabled usb ports
You can remove the M/board battery and leave it out Opinion vary on length of time I use 2 to 3 hours then reinsert it and see
But I reckon its the keyboard use another PS2 and see
Posted on Aug 16, 2008
Access bios in win 7 ?
BIOS is never a part of any operating system. It is firmware that is written in ROM (Read only Memory), built-in hardware on every mother board.
To access BIOS on any computer, please tap "Delete" key several times as soon as you turn the computer on, or if you are good then wait until the BIOS screen comes and hit "Delete" key once.
Jul 19, 2014 | Toshiba Satellite Computers & Internet
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Can't get into BIOS of E5500
Boot the laptop and watch the screen for which key it says to hit to get into the Bios or System Setup. You have to hit the key when you see the message.
May 09, 2012 | Dell Latitude E5500 Laptop
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
Acer Aspire 5102WLMI \ After booting stps for Password. System does not accept any input . Input rom touchpad, key board, Usb keyboad. No usb port is working. I guess, the power may not be coming to these...
On the Motherboard, set the BIOS Configuration Jumper for pins 2 & 3 to clear the password. Turn on the PC for a few seconds and then power it back down and restore the BIOS Configuration Jumper back to normal. The password is now cleared.
Jul 02, 2011 | Intel D865GBF Motherboard
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
No mouse or keyboard input
Do you know how to enter the bios, some notebooks are different, but try hitting the delete key on power up, if not then look at the bottom of the screen it will say hit f12 or f11 yo enter bios, once in, you can go to the page that lists your usb ports, there yu can enable them or disable them, you navigate in the bios by using the arrow keys, and the esc, to exit or the enter key to open a highlighted heading, try that first and if that's all it did then you should be ok, make sure you save your settings by hitting f10 and enter on the way out, and good luck, if you need more help I'll look in on you when I get a chance
Mar 19, 2009 | Acer Aspire 5100 Notebook
Entering the bios
There is 2 way to enter, you can use Toshiba HW setup for BIOS setting from windows. Alternately you can hit ESC several times after turn on the computer and hit F1
Good Luck
Jun 18, 2008 | Toshiba Satellite A15-S127 Notebook
Computers & Internet Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
