Question about Brother MFC790CWG1 / MFC790CG1 Printer
Whilst the printer will print from the computer, I am not able to undersatand the Portuguese instruction manual as to how to photocopy. Can you please provide me with this instruction ?
  • 610 Answers
You can download the manual free from brother-usa.com. look for the tab labeled service and support, enter the model # and you should be able to download it to your computer.
Posted on May 26, 2011
This item ABM4000 was given to us by our neighbors who had just gotten married and had received 4 such items as wedding gifts - very nice of them, however, it had been unpacked and we did not receive
they have things called printers on computers that can print out electronic manuals. you could stick the manual on a tablet for use in the kitchen or find someone with a printer on a computer and print off the file from a usb memory stick. You could reduce the size using a photocopier on reduced setting.
Jan 03, 2015 | Kitchen Appliances - Others
The print is so small in the manual I can not read the instructions for the remote to download the photos
You don't say the make and model of your camera, so I can't direct you to a downloadable manual. However, one way that I make small print instructions more readable is to photocopy them with a size increase. Nowadays most photocopy machines, including those built into multi-function printers, will allow you to "blow-up" the item you are copying to double size or more.
Jan 03, 2011 | Cameras
Printer does not print good copy after doing several head cleaning operations and having enough ink in cartridges.
If the print has horizontal lines of 'missing print' do three head cleqans don't move the printer or switch it off, now leave it overnight - letting the head soak in fresh ink- in the morning, do one more head clean and then print the nozzle check.If it's poor photocopying it is most probably because the print quality for photocopy is set to a low setting. The manual will explain how to change photocopy print quality. Hope this helps
Feb 20, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
Showing check paper mp insert paper
It wants you to load paper in the multi-purpose tray/bypass tray.
Jan 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
Canon IR7105 Photocopier
Hello tophams,
I wish I had a magic wand to help you...but the answer is YES! You can fully control the priorities of how the 7105 handles printing/copying/scannng requests. I truly understand your dilemma, it is merely a matter of how the device has been configured. You can program the device to give priority to copies, which will cause print jobs to wait in the que until your copies are done. You can have the print jobs sent to a "mailbox" so that the person requesting a print job will have to walk up to the device and "summon" their print job. There are so many ways to help you with this. You will have to get "THE BOOK" out. I can't type all of the options available to you.
Jul 03, 2008 | Canon NP 6551 Black and White Copier
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
Won't print
printer will photocopy but will not print from my computer.
I have changed the inkjets.
Mar 27, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Changing Language
I had the same problem with my Canon Smartbase MP730. Printer properties was in Portuguese, no matter how many times the driver was uninstalled and reinstalled.
By running Filemon from SysInternals I realized that when showing the printer properties files in the
C:\BJPrinter\CNMWINDOWS\Canon MP730 Printer\LanguageModules\0409\
folder were created. One of those files was CNMmhya.hlp. When clicking on it a Help-window with Portuguese text shows up - even though the code 0409 means English. This is a symptom of the problem. This file was copied from somewhere in the Windows folder.
To fix this annoying problem, the following worked for me:
-> Unplug the printer
-> Uninstall the driver
-> Rename the following folder with the portuguese language driver stuff which still remains, even after uninstallation of the driver:
C:\WINDOWS\system32\spool\drivers\w32x86\3
(if you cannot rename it, reboot and try again). You should first check that there are indeed portuguese help-files in this folder. To do that, click on one of the .hlp files. If they are not your problem could be a different one, but it could also be that the files are stored nearby in the file system.
-> Reinstall the driver with the language of your choice. This time there won't be Portuguese files blocking proper installation of your new files.
-> Replug the printer to finish the driver installation
Now you should have finally gotten rid of the Portuguese (which may seem Spanish or Italian to some) text in Printer related windows.
Jan 12, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Brother MFC790CWG1 / MFC790CG1 Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
