Question about Fargo 4250 Thermal Printer
Resurrecting dead Fargo 4250
One of my Fargo 4250's is inop ... would like to find a service manual and or parts supply ... this was an expensive machine and I didn't get much use out of it ... get a blinking cursor on power up ... factory replaced mainboard some time ago ... any ideas? ~Jon
  • 526 Answers
It sounds like you have a bad main board again. you might be having some power issues.
we are an ASC for Fargo, if you need parts send me an email. Although the 4250 has been discontinued a long time ago, parts are scarce.
Posted on Apr 23, 2009
Got xp windows, cannot find drivers for fargo printer 4250
Hi there,Due to the age of the printer you only get NT/2000 drivers. You can download them at the site below it also has a guide on how to install. The drivers for NT/2000 should work with XP. You can even try the 98 Drivers.http://www.fargosupport.com/archive_results.asp?archDriver=1&archPrinter=13&archSubmit.x=39&archSubmit.y=6&archSubmit=archSubmit
Regards,
Jul 26, 2011 | Fargo 4250 Thermal Printer
Drivers for Vista Fargo 4250 thermal printer
Hi
Here is a list of drivers for the Fargo 4250:
http://www.fargosupport.com/archive_results.asp?archDriver=1&archPrinter=13&archSubmit.x=23&archSubmit.y=6&archSubmit=archSubmit
Please bear in mind that this is an old printer, therefore fargo have not made any drivers for windows vista. You could download the NT/2000 drivers or the ME drivers and run them in compatibility mode.
Regards
Mike
May 26, 2010 | Fargo 4250 Thermal Printer
I need drivers for 4250 xp
you can download the drivers from the manufacturers web site
Nov 17, 2009 | Fargo 4250 Thermal Printer
Fargo 4250 operational and service manual wanted please.
Hope this helps.
http://rds.yahoo.com/_ylt=A0geu9vVQ6ZJ0FIAS2tXNyoA;_ylu=X3oDMTEydWZ1ZTJhBHNlYwNzcgRwb3MDMgRjb2xvA2FjMgR2dGlkA0gyNjlfOTg-/SIG=12gbeasbg/EXP=1235719509/**http%3a//www.e-scan.com/pdf/Fargo%25204250-4225%2520manual.pdf
Feb 26, 2009 | Fargo 4250 Thermal Printer
FARGO 4250 DRIVERS NEEDED!
They only have drivers up to NT and Win2KPro. Try using the driver in compatibility mode.
Good luck.
Feb 04, 2009 | Fargo 4250 Thermal Printer
Fargo 4250 driver
You could try to install the XP drivers by running them in compatibility mode on Vista. It might work
May 05, 2008 | Fargo 4250 Thermal Printer
Fargo 4250 in XP
Download the Windows 2000 driver. Go to "Settings" then to "Control Panel". Then go into "Printers and Faxes". On the left hand side click "Add a Printer". Check "Local Printer attached..." but make sure "autmatically detect..." is not checked. Then click next. Select the port that the printer is connected to. Then click next and it will ask for the software. Click "Have Disk" and browse to the folder where you saved the driver. It should then find the Fargo 4250 driver and your in business.
Dec 04, 2007 | Fargo 4250 Thermal Printer
Replacing a power supply board
The power supply assembly is quite a thing to get out. You really will need a service manual for the 4250.
Go to http://www.TheServiceManualShop.com and see if they have one listed. If not, ask them to get it for you. They can usually find them within a few hours.
You will need to remove the following assemblies just to be able to start removing the PSU:
● Rear output bin
● Rear accessory cover and tray 2 extension door.
● Top, right-side, and left-side covers
● Fuser
● Formatter assembly
Then remove the PCA guide and the part above it
Remove the power switch arm
Disconnect the PSU cables from the DC controller
Remove the fan cover plate
Disconnect the fan and thermistor connectors
Pull the PSU cable through the frame and you are about there. A bit of wriggling and wrangling and the whole assy should come out.
Oct 16, 2007 | HP LaserJet 4250n Printer
Fargo 4250 Thermal Printer Logo
151 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
