Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Poor suction - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • Official Brand Answer
  • 2,572 Answers
Sorry to hear you're having a problem with your DC07. You should be able to resolve the issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1940&product=DC07-SY
This should restore full suction to your cleaner. However, if you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US). We can run through some simple checks over the phone, and provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 09, 2011
Sanitaire vacuum real noisy..poor suction
It could be something has the hose constricted... You might want to do a little more cleaning inside other than just changing the bag... Have you seen the cat lately? Also check the roller brushes to see if they have something like string wrapped around the ends.
Have a nice day !!!
Feb 24, 2015 | Vacuums
I have a model DC3 rainbow thar has lost suction. what can i do to fix it
Check suction at intake without any hose connected. If that is good, then connect hose and check suction again. If that is poor, then you have a clog. If still good, then check power nozzle by getting into the belt area.
RainVac
www.rainvac.com
800-523-0510
Apr 01, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Fuller brush model fb-dcc has poor suction
All these responses are BS. I have an FB-DCC...AWESOME suction. When's the last time you CLEANED YOUR FILTERS?
May 05, 2012 | Vacuums
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction.
Poor suction can be caused by obstructions, poor air flow or a compomise in the air flow (hole in the hose). Since you have started with that I would next look at all filters and clean them. First check for suction at the motor, then at accessory hose and then the base. this will lead you to a suction issue. If your baelt has not been replaced in the last 6-12 mo I would change that too. check to make sure your carpet setting is coorect for the carpet being cleaned.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 15, 2009 | Vacuums
Bad suction on bissell powerforce bagless vacuum
I took the bottom apart and it needed a new belt and that was the problem so it's fixed.
Jan 16, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Poor suction
i had the same problem and moter cutout for over heating.i removed everything removable to see blockages i found a ball point pen and wood shavings.i cleaned every part possible including the rubber gaskets.also cleaned the bubber gasket in the waste bin.[mine is a 07] still poor suction. i removed side filter washed it in "warm water" and washing up liquid[dyson say to use cold water] the rinsed out in cold water,left the filter over night on a news paper nr the radiator. problem solved..fantastic suction and no over heating.hope this will help
Apr 02, 2008 | Vacuums
Poor suction on carpet
Did you check to see if brush is spinning ,
is belt broken? It could be something stuck
in the mechanism in the impeller, shute,etc
Nov 16, 2007 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
483 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
