Question about Hoover Washing Machines
Have Hoover nextra 6 Kg AAA 1600 HNL662. Set the machine on 40 degree and it goes onto 15 minutes delay and then does not start.(we have not pressed the delay button. And even when we try to cancel the delay it will not let you?.) Can you help please?
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
Biggdex35
  • 333 Answers
SOURCE: cannot open door and lock light stays on
It has a timer circuit that locks the door with a selenoid. It has a sprig that pulls the safety latch back off of the latch. Either it isn't turning the power off or the spring is broken or too dirty with soap and wont work right. Try pulling the power and see if that works. If not got to take front cover off and check it out.
Posted on Jun 02, 2010
SOURCE: can anyone help my hoover washing machine modal
Hi, had same problem the filter was blocked again. It needs to be regurly cleaned out.
Posted on Jun 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: how do I set the washing machine to spin only on a
Adjust the timer to the end of any cycle. The pressure switch will recognize the water presence, and drain before spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
  • 24 Answers
SOURCE: My Hoover 1600 AAA Vision
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Posted on Jan 17, 2011
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
Jan 17, 2011 | Hoover AAA160 Front Load Washer
Cannot open door and lock light stays on
Jun 01, 2010 | Hoover AAA140 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
How do I set the washing machine to spin only on a Hoover Nextra HNL662?
Sep 05, 2009 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Washing Machines Logo
119 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
