Question about Olympus Cameras
Does the olympus x15 charge through usb connected to the computer?
  • 6,487 Answers
This camera charge using the charger that came with it and the USB portion of it is only for file transfer from camera to computer.
Transferring pictures from camera to computer use the usb portion of it and not for charging purpose.
Posted on May 26, 2011
Olympus vg 170
To make it possible, to point out where the problem is, you could try some rings.
Try to charge the camera with an external power supply. If you have it, the F-2AC from Olympus.
If that also does not charge, you could try to replace the USB cable.
But if the camera starts charging, you have to look for the USB connector in the computer. Be aware, in some computers the power, delivered from a USB connector, should be capable of giving 5 volt and 500 mA. Sometimes internally the computer is not correct wired, and won't give the 5 volt at all. Special when you hav build the computer yourself, you can check inside the computer. BUT ONLY when is sure the camera can charge via an external USB charger.
Then you could check if nothing is wrong in the camera. All contacts, on battery and in the camera, should be clean and shiny. You could clean contacts with a dry cloth. Never use sharp tools.
Also check the USB connector on the camera, if no debris is in the connector, or no contact is bent or has corrosion on it.
Success
Mar 04, 2014 | Cameras
Have no drivers for samsung x15
Use a computer that has Internet connection to download the Samsung drivers and then copy the drivers to an USB memory stick to install on your Samsung laptop.
You can download the device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
Sep 01, 2012 | Samsung X15 Notebook
The battery will not charge ,usb port with out the battery camera will not power up
This camera does not charge via the USB cable, the cable is used to download the photos to the computer.
This camera uses a recharageable lithium battery and the battery needs to be removed and connected to an external battery charger to be charged.
You can download a user manual from this WEB site.
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_fe280_e.pdf
May 28, 2012 | Olympus FE-280 Digital Camera
Is it possible to charge my olympus fe-46 from my computer?
In a convoluted way. The FE-46 uses standard AA batteries. You may use either disposable alkaline or lithium batteries, or rechargeables. If you use rechargeables then you must charge them outside the camera. There are chargers that run from a computer USB port, and there are even AA batteries that plug into a USB port. However, you canNOT charge the batteries by connecting your camera to your computer.
Jul 29, 2011 | Olympus FE-46 Digital Camera
My cammera will not charge! The orange light does not show up when charging ???
There are 3 possibilities to charge the battery of the camera:
1. Connecting the Olympus' USB cable to camera and computer.
2. Connecting the wall charger to the camera with Olympus' USB cable.
3. Using a specific separate wall charger for LI-50B batteries.
Be sure to connect the cable well and if the orange LED does not light when trying to charge the battery using above points 1 and 2, there might want to exchange the Olympus' USB cable first to check what's wrong. (Cable model: CB-USB6). Another point is to check if the battery is seated well in the camera.
Jun 05, 2011 | Olympus SP800UZ Digital Camera
Samsung x15 - Operating system not found.
sounds like an issue with your hard drive. you could try running chkdsk /r either by removing the drive and connecting it to another computer as an axternal drive using a usb hard drive adapter or using something like the hirens boot disc, going into mini xp and do the check there.
http://www.hirensbootcd.org/download/
Apr 09, 2011 | Samsung X15 Notebook
Can i charge an Olympus fe-4000 with a usb cable connected to my computer?
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Jun 28, 2010 | Olympus Cameras
Can you charge a olympus stylus 820 through a usb?
No. Connecting the camera to a computer drains the battery since the camera has to communicate with the computer. Use the supplied battery charger to charge the battery.
Mar 16, 2010 | Olympus Stylus 820 Digital Camera
Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Jul 02, 2009 | Olympus FE-20 Digital Camera
Cameras Logo
80 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
