Question about Lexmark X1270 All-In-One InkJet Printer
How do i photo copy. have plugged printer in but not connected to laptop just want to copy some paper work i have.
  • Lexmark Master
  • 32,281 Answers
You can scan and copy a document (photo copy) with this printer without conecting it to a computer. These instructions are in your User Manual. If you have lost it you can download it from this WEB site.
http://www.lexmark.com/publications/pdfs/1200/eng/ug.pdf
Posted on May 26, 2011
2 Suggested Answers
  • 352 Answers
SOURCE: tried to copy photo using scanner used photo
Hello.
Simply unplug it from the wall for 10 mins, then plug it back in and try again. Sometimes after a jam a re-start is needed.
Regards GM
Posted on Aug 01, 2011
Photo paper jams when I try to copy print, or copy from computer. Copy paper works fine
Hi Lawrence Lewis,
I would be happy to help you with your Officejet printer. If I understand correctly, you can print and/or copy on plain paper, but not on photo paper, is this correct?
What printer model do you have? How Do I Find My Model Number or Product Number?
Knowing your printer model will help me to better assist you.
I look forward to hearing back from you.
I work on behalf of HP.
Jul 13, 2015 | HP OfficeJet Office Equipment & Supplies
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
Tried to copy photo using scanner used photo glossy paper , paper got jammed in printer pulled out paper from front of printer , now printer wont print from computur , help needed .thank you
Hello.
Regards GM
Aug 01, 2011 | HP Office Equipment & Supplies
Paper will not feed
when you printer mechanism going to be old it can not turn your photo paper. change the rubber of roller it will be solved
Oct 25, 2009 | HP Office Equipment & Supplies
Nothing prints on paper
Kodak printer 5500 make out photos with UltraPremium Paper very flashy even with darker photos shots,
tried calibrations with photo paper kodak says: no suitable paper format
Feb 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
Horizontal lines when printing photos from Canon MP700; have done all cleaning maintenance; only happens when printing photos -- whether from computer or copying;
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon S 750 InkJet Printer
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
Lexmark X1270 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
