Question about Timex Ironman Triathlon 51931 wristwatch
Replaced the battery, whole display is just blinking
I changed the battery in my Kenneth Cole KC1658 watch and nothing is showing on the screen...it is displaying a black. How do I turn the watch on?
1.make sure your battery good condition.
2. make sure installed properly.
3. reset movement there is two whole on circuit board use stapler pin to connect both whole for one second remove pin
your watch display should show up .
Oct 02, 2014 | Kenneth Cole KC1658 Watch
The digital display on my timex epedition watch is frozen... nothing I do changes this, holiding down any of the buttons does nothing
You have to check if the digital part has separate battery. It is quite common to have two batteries in one watch - one for each movement. If this is the case, replace battery. If there is only one battery for the whole watch, you will need watchmakers help to rectify the fault.
Feb 27, 2011 | Watches
How do i get a replacement resin part of the watch
mcdevito75 here, If you mean the display where you see the time, Day, date etc. it will pay to replace the whole watch, these displays can be very expensive as they are the heart of the watch. Best Bet, replace the watch with a new one.
Feb 09, 2011 | Casio G-Shock G701D-2AV Wrist Watch
On my Kirium F1, the digital display keeps blinking. How do I make it stop, or is this the signal that I need a new battery?
Yup, it means it's time to change the battery. However, if it's blinking despite having a new battery, it could be because the time and date needs to be set.
Here's a copy of the manual for more info :-
http://www.mediafire.com/?qgq1p3329sbe7s1
Hope this helps.
Jan 10, 2011 | Tag Heuer Kirium Formula 1 Chronograph...
Tag kirium f1 crown does not work, light does not come on for 6 seconds, also buttons do not work
Is the digital display blinking? If it is, it would mean that the battery is weak and thus, the backlight won't work.
Dec 17, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
My Puma watch screen went blank?bought it April of 2010 at nike store in chicago? model 910192001? How do I solve this problem. I know its under warranty
If it had been sitting on display for long time the battery might need replacement. I'd take advantage of the warranty and have them replace the whole watch.
Jun 02, 2010 | Watches
End-of-life indicator for Victorinox Night Vision II watch - I seemed to remember that the watch battery can be monitored through the red LED that blinks every 10 secs. when it is OK, if the battery needs...
Not a malfunction - just a dead battery. See the manual:
http://www.victorinox.com/medias/sys_master/timepieces_manuals/8800396705822/NightVision_II_ENGLISH.pdf
May 12, 2010 | Watches
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
CHARGE LIGHT FLASHING
it means the battery is going dead.
Mar 02, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 | Watches
Timex Ironman Triathlon 51931 wristwatch Logo
100 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
