I forget my password which i entered in wifi - Computers & Internet
  • 141 Answers
Hi you can change your wi-fi password by logging onto the wi-fi router.
2 options:
Option One:
Some times you can reset the router by pressing in the reset button found on the router for 10-20 seconds this will then change all your setting back to default. The default wireless passwords can normally be found the manufacture website, ISP website or at the bottom of the router depending on the model.
Option Two:
To do this you will need to connect you computer/laptop to the router with a Ethernet cable that way you do not need to use the wi-fi. Once this has been done you are required to enter your router IP address depending on the model of the router it normally 192.168.?.? (? indicates an number) (This can normally be found on the manufacture website or in the manual).
Once you have done that you are ask for a log-in and password as-long has this has not be changed you can normally find the default password and user name in the manual.
You can then change the password though the interface you will reclive once you have done the above.
Posted on May 26, 2011
  • 328 Answers
If you forget the username or password, or if the configuration becomes really messed up, you can always clear all the non-volitile parameters by doing a 'factory reset'. To do this, with the router already fully booted, press and hold the reset button for 5~6 seconds and release. The router will boot back up and answer to just as if it had just been flashed with DD-WRT.
I cant get on my wifi.will not sign on .authorization problem.
authorization problem is bad password
choose forget network
reselect network
check show characters to be sure
enter correct password
dont know password login to router and change wifi password
save settings
Nov 14, 2016 | Cell Phones
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Can't connect to WiFi connects but says saved
You need to press the "forget" button the next time you try to connect, and then let the tablet find the router again.
You apparently have tried and not entered the proper password, and now when you try to connect it is still going to wrong password.
Once you press "forget" it will reset and you can enter the password again.
Good luck with that.
Feb 17, 2016 | Tablets & eReaders
My 7" DELAND DK701Q won't connect to the Internet thru wifi, what do I do?
Are you trying to connect to a wireless access point that's running WPA encryption and the tablet won't talk to a WPA access point?
Are you sure you have the password correct?
Mar 25, 2015 | Tablets & eReaders
I could not turn on my the wifi on my chromo tablet
When you selected forget it erases the SSID and password you entered to connect initially so you will have to re- enter the info to reconnect!
Feb 15, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
Lost password
Enter the settings page on the modem and change the Wi-Fi password to something you won't forget, use a daft sentence like 'my cat wears wellingtons' so you will remember it.
Mar 11, 2014 | Thomson Speedtouch St585 V6 Sl Wireless...
Put in wrong password for wifi and then accidentally hit forget and now it wont let me type in a password at all
You need to select the wi-fi website again, and enter the password again. It will then store the password.
If you forget the site, it forgets the password connection to the site and you have to start again.
Feb 14, 2014 | Kocaso 1.2GHz 4GB 7 inch Capacitive...
My Kocaso M752 says it's connected to our wifi but it hasn't asked for the password.
The programmed password is stored on the android tablet, from last time.
Until you say "forget" site
Feb 09, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
Wifi setup password
Confirm you do not have caps lock on, or are on a laptop with numlock on first. Assuming those basic settings are off, next you want to try and add the password in cleartext. In the wireless list, right click on your wifi network and select properties. Underneath the network security key should be a check box that says show characters. Click that and your password should be readable. Confirm it's correct or retype if not and try again.
If that does not work you may need to log into the router itself and reset the wifi password.
Nov 26, 2013 | Arris SURFboard® SB5101 Cable Modem
Accidentalypressed forget button adnhave no access to wifi
Settings/Wifi - Assure the Wifi lists that it is turned on - if it is showing it is in the off position, flick toggle from left to right - once on, look for your network and you will have to re-enter password - click "Join" there you are
If for some reason you do not see your network, check your wifi modem - try resetting it... anymore questions you can email me directly
Nov 11, 2012 | Apple iPod touch
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
