Question about Raritan (DCIM-USB) 1-port KVM Switch
I need to reset my Raritan KVM password, the techie that set it up resigned a few yeears ago.
Keyboard mouse not working
U must go in bios and change settings for usb device: enable
Jul 10, 2014 | Raritan Computers & Internet
D2CIM-VUSB can use USB 1.0?
They should work, but I would use the PS2 connectors to be sure.
May 15, 2014 | Raritan Computer KVM Extenders...
I need rest i tried backside rest button but icant
Press and hold the reset button for about 20 seconds, it should reset.
Dec 27, 2012 | Raritan Computer DKX2-108-PAC - Raritan...
Raritan SW2USB. Has been working for several years. Today started normally, but suddenly the keyboard was not visible to the switch or either computer. Checked cables, rebooted, etc. Bought a new keyboard...
It sounds like the main switching IC on the board has gone bad...seen it happen before.
Your best bet is to replace it, I would check on Ebay for a good replacement a little cheaper than retail
Aug 20, 2011 | Raritan CompuSwitch CS2 (CS2-PENT) 2-port...
Hello! I asked yesterday about Raritan Dominion KX216 and password reset problem. You answered: "Look for a reset button, and press it for 30 seconds. that should restore factory settings, then...
there should be sound button on the side of the device along with the power button.
push the audio plus and power at the same time.
a menu to restore is there. do this with the device off.
Aug 02, 2017 | Computers & Internet
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
UMT242/USTIP2 not accepting remote clients, local only
I do not know this particular IP KVM but most IP KVM's use SIPPs that must be updated on the KVM when they are attached to the servers. Look for an option in the admin tools that say update SIPPs or update connection. You may also just have to double click on the list of connections to get it to update. This may have to be done at the console and not via remote.
Dec 18, 2008 | Raritan Paragon UMT242 (p2-umt242) 42-port...
Raritan (DCIM-USB) 1-port KVM Switch Logo
820 people viewed this question
Top Raritan Computers & Internet Experts
Mike
Are you a Raritan Computer and Internet Expert? Answer questions, earn points and help others
