Question about HP OfficeJet Pro L7580 InkJet Printer
My HP Officejet Pro L7580 All-in-one printer appears to need its feed rollers cleaned because when I print pages on both sides, I find side 1 comes out with about six dirty bands down the page, each approx 1.5 cm wide. Any suggetions how I can fix this would be welcome. Thanks.
  • 1,179 Answers
Use tissue paper to try and clean as mush off as you can. Surgical alcohol may do the trick as a solvent. It's either the roller or the guide wheels that help feed the paper through the printer that have come to ink that are causing the lines.
Try and get to them without taking the printer apart, as it can be a complecated affair. However if it is the only way, be sure to place the screws in a screw divider and don't rush. Go slowly and take photos of the disassembly as you go.
Another option is to get a printer technician to do it for you.
Take care!
damnor01
Posted on May 26, 2011
Testimonial: "Thank you for your help. I'll try that in the weekend!"
I have network printer with scanner. Model is hp officejet pro L7580 printer. I installed a printer sucessfully but I want to use printer scanner. So how to install scanner & use it?
Hello!
In order to install your scanner, you need to print a test page. As you need to align the cartridges, you also need to align your scanner. See the printed alignment page for directions on how to complete the alignment process. Basically, all you have to do is put the test page in the scanner and press scan.
Mar 31, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How to clean out fees rollers
Open the back cover and you will see the feed rollers.
Oct 14, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Voucher checks not printing correctly HP C7280 AIO
The front of your voucher check is smoother than normal paper or the rear of thr voucher. Cleaning the feed rollers should fix this problem. If you do not know how to clean the rollers, you need to take the printer for a service.
Aug 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580: says load paper/won't print
Go to printer and faxes and cheeck the preferences of your printer cheeck the number of copies and all strange that you will saw.
i hope my advice is helpful.
May 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have an HP Officejet Pro 7580. When printing in
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The paper won't advance enough to print in our HP officejet 7580
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Lines across printed page on photos
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
Jan 05, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
