Question about Hotpoint Ovens
I have a hotpoint SE861X oven which has suddenly stopped working. The clock and timer are on but the fan and light won't turn on in the oven. What could cause this to happen?
SOURCE: Hotpoint oven clock
1 make sure all oven controls are turned off 2 press & Hold in both the cook period & end time buttons together 3 with both buttons still held in press either the + or - buttons to set the correct time of day 4 Release all buttons simultaneously the time of day is now set.
Posted on Oct 01, 2007
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
MNTECH
  • 1543 Answers
SOURCE: Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Posted on Aug 28, 2008
SOURCE: Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Posted on Feb 05, 2009
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Smeg oven stopped working
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 27, 2012 | Smeg Ovens
Our Hotpoint Microwave Model #RVM1435 won't heat. The blower, timer, clock, service light and vent all work, but there is no heat. Could it be the power control??
Unfortunately, it could be the magenetron (P/N: WB27X10017) that is bad. And they aren't cheap. But it could also be the thermostats (there are four of them) or the high voltage diode. Without being able to put a meter on things it is hard to say exactly what is going on.
The most likely in the magnetron, especially if it is very old and used often.
Sep 06, 2011 | Ovens
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Oven not heating
Hello.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Aug 27, 2008 | Ovens
Ovens Logo
24 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
