Polarity of cassette player
Hi!  We're trying to identify the polarity of an old GE 3-5025A cassette player so that we can properly install a replacement universal power adapter and not destroy the cassette player.
Do you know this model's polarity?
thanks,
Kate Lucchese
Vulfen
  • 5 Answers
SOURCE: Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
Posted on Jul 15, 2007
SOURCE: DC power adapter
The adapter for the DE-805TP supplies 9 volts dc at around .5 amps
Posted on Jan 13, 2008
Bubbabear64
  • 2794 Answers
SOURCE: power supply adapter
12VDC 750MA tip positive.
Posted on Jun 13, 2008
SOURCE: lost my power adapter, need polarity
Output 12VDC 1.5amps or greater 1500mA
Center conductor positive.
Posted on Feb 26, 2009
SOURCE: Maxtor personal Storage 3200 Power Supply [K01PWR3200]
i own the exact same drive. i'm looking for a spare power supply, came across this website, and saw your problem. the power supply is 12 volts dc at 2 amps. the connector that gets plugged into the hard drive: center pin is power (positive) and outer "shield" is ground (negative). hope this helps.
Posted on Jul 17, 2010
How do I re connect my equipment after a move?
Your input's that you need to use are labeled on the rear of the chassis. Make ALL of your connections with the power cord unplugged.
The connection types for each component that you'd like to use are also labeled. For the CD player you may see such connections as coax, optical or L&R...you need to only connect one type. What's available depends on your receiver. For a cassette tape player however there will be only L&R, connect from the L&R outputs of the player into the L&R input on the receiver.
For your speakers, you have a couple of options depending on what you have connected to your speaker cables but the most important thing is getting the polarity connected properly. Not all speaker cables are color coded for polarity but instead have a marking on the insulating sheath along the entirety of it's length or may simply have one silver wire and one copper wire. You only need to make sure that the polarity of the connecting terminals between the receiver and speaker match; having the cables marked is only to make that connection easier...just connect one wire at a time, and make sure that your speaker placement position also matches the terminal you're connecting to.
Dec 28, 2014 | Audio Players & Recorders
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
RQ A200 cassette player stop working
If your battery polarity was reversed then there is a possibility that a protection zener diode onthe set could be short as a prevention. so you will have to check on the + line input to the set. If not the amplifier could have shorted depending on the applied power. Anyway you will need a good check onthe main board to confirm this but I think with a tech help, it will not be difficult. Hope I could help. Good day
Jun 12, 2010 | Panasonic RQ-A200 Personal Cassette Player
Cassette player's buttons (play, fast forward, rewind)
It is repairable probably just the tensioner springs need replaced or the guides are worn they can repaired as well the problem will be finding someone that still does repairs to this type of equpment.
Dec 14, 2017 | GE Audio Players & Recorders
What is polarity? & help with hooking up mp3 player to car?!
POLARITY MEANS +/- AND NOT TO REVERSE. FOR EXAMPLE ON A SERIES WIRING SPEAKER SYSTEM YOU REVERSE POLARITY EVERY OTHER SPEAKER SO THE OHM LOAD DOUBLES. OR ON ELECTRIC CARS SERIES WIRING DOUBLES VOLTAGE OUT PUT AFTER EACH BATTERY IS HOOKED UP.... BASICLY POLARITY IS POSITIVE ONE SIDE NEGATIVE THE OTHER MOST CASES YOU DONT WANT TO GET IT BACKWARDS POSITIVE TO NEGATIVE ONLY CONECT SAME+ TO OTHER + UN LESS YOU KNOW WHAT YOUR DOING. WHAT POLAITY HAS TO DO WITH AN MP3 ADAPTER I HAVE NO IDEA...WAIT... DOES IT CHARGE THE MP3 PLAYER??? DOES IT HAVE AN ADJUSTABLE VOLTAGE OUTPUT SWITCH?? THATY YOU PLUG IN TO MP3 PLAYER??
Feb 08, 2009 | Car Audio & Video
Nakamichi DR2
Check belts. If mechanism is not in proper position, sensors will send ERROR signal to micro processor
Feb 03, 2008 | Audio Players & Recorders
Car Cassette player noise
try installing a inline noise filter in the hot wire running to your tape player, you can get one at radio shack.
Sep 19, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
83 people viewed this question
 Grubhead
Grubhead
