Need serial for usb disk security 6 - Computers & Internet
    Scholar:
  • 81 Answers
How to fix error message please insert disk into removable disk
which operating system ?
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Jan 04, 2014 | A-Data Technology Adata USB C802 8GB BLK...
Tip
How to flash your disk [USB]
How To Flash Your Flash Disk
[ USB ] Universal Serial Bus
  • First : Open Your USB Disk ( Like The picture )
  • There are two black Ships , marked with Three codes
  • A code has 6 Numbers , A VID Code and A Pid COde
  • copy all the codes to a bloc-note
  • open this site : http://www.flashboot.ru/iflash.html
  • Write The First Code Second Code and The Third code (Like The Picture)
1) Click Enter
2) The Site Give's You A lot Of Information
3) Choose You usb Disk Data (See The Picture)
4) Download The Flash Application
5) Connect Your usb Disk On The Computer
6) Open The Flash Application
7) It give's a button written on it : << Flash /or/ Preformat >>
8) Push The Button , Wait For A minute
9) Your usb disk Will Be Flashed ;)
Fix-shad0w
Please Rate .
on Jul 07, 2010 | Computers & Internet
How to fix please insert disk into removable disk
W 7
for XP or earlier
Jan 04, 2014 | A-Data Technology Computers & Internet
Can't access freecom storage USB disk
w7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Dec 21, 2012 | Freecom network Media Center 500GB, Gb LAN...
GhELLO : I NEED TO DO UPDATED THE BIOS FROM USB PORT?
The USB ports are controlled by the OS. Try the following:
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
Aug 04, 2011 | Sony VAIO VGN-AW330J/H Notebook
How do i put my hard drive inside? me
Open the external case, by removing some screws, and sliding the cover away from the insides.
Connect your disk-drive to the "power" and "data" connections, and secure the disk-drive with the mounting screws. Close the case.
Jul 25, 2011 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
I can't get the Notebook to recognise that a mouse has been plugged into the mouse port. I have found out how to disable the touch keypad FN and F9 but not how to enable the mouse.
You may need to refresh the USB ports. Follow the instructions below. You do not have to disable the touchpad to use an external mouse.
Mar 25, 2011 | Advent Netbook
I want serial key.
Contact the software makers website.they will send a new key.RICHARDM69
May 03, 2009 | Computers & Internet
Need a USB converter for some serial thing
dynex puts out a usb to serial adapter can be bought at best buy for somewhere around 15.00 you will need the drivers from the cd to make it work and then will probably have to set the port it is looking for that should be all you need
Dec 05, 2008 | Toshiba - Floppy disk drive - external -...
Computers & Internet Logo
David Payne
David Payne
