Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
"service error 5010" how can i
  • 214 Answers
SOURCE: Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on May 14, 2009
SOURCE: service error 5010
errore code 5010
Posted on Dec 25, 2007
SOURCE: Canon pixma mp145 service error 5010 How to
i have error code 5010 showing?
Posted on Jul 24, 2010
caroldon
  • 17130 Answers
SOURCE: Hi. After I refiled the
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Thank you for using Fixya
Posted on Aug 11, 2011
  • 827 Answers
SOURCE: how to solve service error 5010 on canon pixma 140..
Hello - This is a good question where I am stumped.
Have you tried contacting the manufacturer's tech support line? They may be able to help.
Best regards
Ck
Posted on Nov 11, 2011
How to solve service error 5010 on canon pixma 140..
Best regards
Ck
Nov 10, 2011 | Office Equipment & Supplies
CANON ERROR CODE 5010
There is an issue with the purge unit inside the printer.
If you are under warranty you are in luck, but first ask yourself how old is the printer and is it worth fixing and if not get a new one.
Jul 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Olympus FE-5010 Card cover open error. Card cover is closed. Tried a new battery and new card. It didn't help.
i hv olympus fe 5010 nd problem is "write protect" error sawing .....so how i cn solve it
Jun 27, 2009 | Olympus FE-190 Digital Camera
Card cover open error message...
The problem you are describing is a problem with the sensor on the card cover door It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service. http://olympusamerica.com/cpg_section/cpg_servicerepair.asp Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $101.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 10, 2009 | Olympus Stylus 850SW Digital Camera
Service error 5010
that is a scanner error code , prob not worth fixing cost you more to have it fixed than the printer is worth
May 20, 2009 | Canon Office Equipment & Supplies
To get ride of Canon Pixma MP160 Service error 5010.........!!!
Pliz help me out and fix the service error 5010 which i get as soon as i turn on my printer and due to which the alarm light starts blinking, i'm helpless coz either my printer or Scanner isn't working, so pliz stretch out your helping hand in order to let me get ride of this.
Regards,
PRINTER DOT COM
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code
Hi Jakabi. That error code means there's a defective module in the printer. It's not user replaceable, unfortunately. The only solution is to contact the store where you bought it, or Canon's tech support to get a replacement. That comes directly from Canon support ! I know it isn't what you'd like to hear, but unfortunately it's the only way out of it. Thanks ! cheebster.
Jun 20, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
286 people viewed this question
old marine
old marine
