Question about Motorola Mobility H700 Wireless Headset
Motorola bluetooth H700
Thanks for your website.
I was able to pair my bluetooth with my phone.
However, what do I have to do to be able to call handsfree?
Thanks!
  • 3 Answers
The password is 0000
Posted on Aug 18, 2008
I have motorola bluetooth but i dont have password.
Posted on Aug 17, 2008
SOURCE:
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
Bluetooth serial # 6809501a26-0 need
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'. 4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Sep 01, 2010 | Motorola Mobility H700 Wireless Headset
Tryin to get bluetooth earpiece to work on motorola razor phone
Go to this website, then click quick start, then click pair h700 with your phone and then it will give you steps to take to pair it. If i helped please leave me a rating.
Mar 22, 2010 | Motorola Mobility H700 Wireless Headset
HOW H700 BLUETOOTH CAN PAIR WITH SONY ERICSSON 750i MOBLIE ?IS THERE ANY SOFT WARE TO BE INSTALL IN MOBILE AND FROM WHERE I CAN SOFT WARE FOR H700 MOTOROLA BLUETOOTH. THANKS
Go into the phone's bluetooth settings and set it to search for devices, then press the answer button on the H700 for about 10 seconds or until the light stays on steady and your phone should pick it up as an available device if it doesn't work the first time, repeat until it picks up the H700 and use the code "0000" when prompted to complete the pairing.
Sep 16, 2009 | Ericsson Cell Phones
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
H700 bluetooth ear piece - Pairing with new phone
Press and hold the call button while the boom is in the off position for 4 to 5 seconds. The blue indicator light should come on and stay on. The unit is now in pairing mode. Initiate you phones feature of searching for bluetooth devices and pair the two together. The default passcode for the H700 is "0000" four zeros.
Good Luck
Jun 22, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 Bluetooth Headset
The password is on the H700 and can't be changed. It is 0000 (that is 4 zeros).
May 24, 2008 | Motorola Mobility H700 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
238 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
