Picture bows in the middle and images appear double
  • 927 Answers
Good Day, kizzysep;
Curved picture, this indicates that you have a convergence circuit that has failed, if your TV is a rear projection. I would recommend that you contact an Authorized Service Center for your TV and have them give an estimate before repair.
Depending on the age of your TV it might be wiser to buy a new TV, but get an estimate first.
Good Luck, big IRISH.
Posted on Aug 16, 2008
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Picture bows in towards middle
YOU HAVE A ALIGNMENT PROBLEM, ON YOUR BOW OR PINCUSION, OR A BAD RESISTOR, THE COLORS NOT LINING UP COULD BE A CONVERGENCE PROBLEM. I ADVISE YOU TO LET A EXPERT TO THIS DUE TO THE HIGH VOLATE ON THE CRT(PICTURE TUBE)
Jun 07, 2009 | RCA Televison & Video
I cant upload my pics to my computer
How To Transfer images To Your Windows XP/VISTA PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To transfer images from your camera to your Windows XP PC, follow these steps:
  1. Connect your camera to your PC using the USB cable.
  2. Turn your camera on, and then select the 'Computer' option on your camera.
  3. After you have selected the computer option, a pop-up appears on your PC informing you that Windows has found new hardware. Close the pop-up.
  4. Double click the 'My Computer' icon located on your desktop. The My Computer window appears.
  5. Double click the 'Removable Disk' icon in the My Computer window. The Removable Disk window appears.
    Note: The drive letter associated with the removable disk may be different depending on your system.
  6. Double click the folder names DCIM in the Removable Disk window.
  7. Find the folder named 101SSCAM. The images taken with your camera are in the folder.
    Note: Each folder in your camera contains up to 99 images. Once this limit is reached in an existing folder, your camera creates a new folder. The folders are labeled successively: 102SSCAM, 103SSCAM, etc.
  8. To copy the entire folder to your PC, right click the 101SSCAM folder. A menu appears.
  9. Highlight 'Send To' in the middle of the menu. A sub menu appears.
  10. Select 'My Documents'.
  11. Windows copies the folder into 'My Documents'. Depending on how many photos are int he folder, copying may take a few minutes.
  12. Double click the 101SSCAM folder in My Documents to access and view the pictures taken with your camera.
How To Transfer images to Your Mac PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To Transfer images from your camera to your Mac, follow these steps:
  1. Turn on your Mac, and then connect your camera to your Mac using the USB cable.
  2. Turn your camera on, and then select the Computer option on your camera's screen.
  3. An icon appears on your Mac desktop labeled Untitled.
  4. Shortly after, a pop-up appears on your Mac desktop. Click 'Download All' in the pop-up.
  5. After downloading is complete, another pop-up appears containing the pictures taken with your camera.
Dec 31, 2008 | Samsung L200 Digital Camera
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Zenith rear projection tv 56"
You have a convergence problem. Go to the convergence menu or consult the owners manual on the convergence procedure and try to correct i if you can.. However if the red image is bowed and or not linear you will probably need to call a technician to repair your set. Most likely the red convergence output chip has failed. This is a common problem with all CRT ( picture tube) rear projectors. Good Luck. Happy Easter
Mar 23, 2008 | Zenith R56W36 56" Rear Projection...
Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
Sep 08, 2007 | Mitsubishi WS-65819 TV
Curved picture and double images
I had noticed your question before posting mine, since it appears no one had given you a solution thought i would share the solution given to me. Two different techs told me the same thing it would need a new convergence board. I ordered my board today hopefully have fixed soon as it arrives. I noticed your question has been hear awhile but thought maybe if you still needed some help I would share. It is going to save me $300 doing it myself, but if you are going to try make sure to talk to one of the techs first on live chat. Goodluck
Sep 02, 2006 | Samsung PCN5425R 54" Rear Projection...
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
