Question about Toshiba TEC B-SX4 Thermal Label Printer
When I print out a label, I can onl get data to print on the top half of the label. On a one inch tall label,data only prints on the first half inch. Data for the bottom half of the label prints on the topm of the next label. Is there a calibration/configuration that needs to be done?
    Champion:
  • 254 Answers
Check the parameters.
Too much feed adjust etc.
The best solution is do a factory default and try printing again.
Posted on Aug 16, 2011
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
http://ulearnoffice.com/word/printing.htm
Thanks,
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
I have a brand new zebra tlp2844 I have set it up with a resin ribbon, the print quality is very poor and patchy why is this ?
There are a couple of possible solutions.
1/ Resin ribbons are meant to be used on synthetic labels onle ie vinyl or polyester. If you are trying to print on paper labels then you will get a rubbish print. you need to use either a wax ribbon or a wax resin ribbon.
2/ If you are printing onto a synthetic labels and the print is light, try increasing the "print darkness" some times called contrast or heat or printhead setting.. This can be fount in the printer set up in the labels software you are using or in the print drive under "Print Preference"
Dec 16, 2012 | Zebra TLP 2844-Z Thermal Label Printer
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
Jul 21, 2009 | Zebra Z4M Printer
Zebra 170PAX3 not printing the top half of label
If you print a power on test label, see if the print is aligned, id so, use the top of form setttings to get all the print on the label.
As far as a USB, the printer will only take RS232-422,485, and parallel, and you can add the factory Nic card or use an external print server.
Dec 08, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Not printing on whole label
Mine was doing this until I followed the steps to recalibrate it. Sometimes it goes back to printing incorrectly and I just recalibrate it again.
Feb 12, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
660 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
matt
matt
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
