Question about Sony SLV-679HF VHS VCR
Error code 30109 slv-se70 - Sony SLV-679HF VHS VCR
Have a Sony SLV-N71 VCR with error code ASC or AC5...not sure. Can you explain?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Sony SLV-N71 VCR
Where do I find a description of the error codes for a SLV-D370P Sony DVD/Video Cassette Recorder? I have been trying to create a CD from an old vinyl record and the SoundForge software that came with the...
You`ll find the error codes in the service manual, But I don`t think this will help you, it sounds like you have a compatability problem. Are you not better connecting your turntable up to your PC?? You can purchase these really cheaply out of ASDA and other good retailers now which will plug directly into the USB port. You`ll have no problems then, I promise, I`ve done it. Ian
Jul 29, 2009 | Sony SLV-D300P DVD Player/VCR
I have a sony vcr model slv-799hf, with a error code displayed 30109. The tape will not rotate. Dan: dodge1989@att.net What does this error code mean?
SYMPTOM: Unit does not load or eject. RESOLUTION
Replace slider with new part number 397744203
SYMPTOMS
No playback video.
RESOLUTION
Located and removed solder short between pins 9 and 10 on IC1201.
For error codes for this model, you might need the full service manual.
Contact me at billyjones@fletchersite.com if you need this.
Mar 09, 2008 | Televison & Video
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Sony SLV-679HF VHS VCR Logo
182 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
