Question about Lexmark Office Equipment & Supplies
Where is the resivoir to top up power steering unit
  • Lexmark Master
  • 3,594 Answers
LIST THIS SOMEWHERE ELSE.
Posted on May 26, 2011
Where is power steering resivoir
That reservoir is the power steering pump itself. You'll see the power steering pump, driven by the belt that runs the fan, and it has a pully driven by the belt and there is a twist cap on top of this tank. That's where you put in power steering fluid.Just remove that cap and fill it with fluid.
Nov 30, 2014 | Cars & Trucks
The steering is getting really hard to steer..
first pop ur hood
then look towards the back of the motor of your car
u will see a big cylinder shaped booster with a resivoir coming out of it.
this is your brake booster and master cylinder these fluid levels mean nothing as far as your problem is concerned.
keep looking and you will find another small resivoir with a cap on it.
this is your power steering fluid.
take the cap off and check to see how full it is.
you most likely have a leak in either a power steering line or your power steering pump is faulty and leaking. this will cause hard steering if youre fluid levels are insufficient.
hope this helps you with your problem.
Brian
Feb 06, 2011 | 1999 Oldsmobile Alero
Where is the power steering fluid in a 2005 buick rendezvous
Depending on which pump they used ,if it is the pumpwith resivoir it would be on the belt side in the front .The cap will be a plain black cap.If it is the pump with an external resivoir it would be either on the firewall or mounted on the fender .It should have a black cap with power steering or power steering fluid written on it.I hope that helps a little bit.
Jan 30, 2011 | 2005 Buick Rendezvous
Where s the power steering top up resivoir on my honda civic 1400 imagine??
Follow your fan belts. One of the belts operates the power steering unit. The resivor should be right there with the power steering unit. It is best to check the level when motor is cold. If it has gone completely dry then you will need to get the air out of it after adding fluid. To do this you add the fluid then turn the steering wheel all the way to the right and then back to the left several times. After the steering wheel feels smooth while turning it then you are good to go. Recheck the fluid first after you have turned the steering wheel back and forth and top it off to the mark on the level stick. Hope this helped, raz
Apr 18, 2010 | 2003 Honda Civic
Power steering reservoir has a bad leak. How do I
I think but please dont quote me on this, there is a easy fix for the resivoir leaking from between the pump and the resivoir. you can remove the powersteering by removing the serpentine belt and then turn the pully to line up the 3 bolt that secure the p/s pump. removed the resivoir by removing the clips, replace the seal ("O") ring for the resivoir and reassemble, reinstall and then retest, Hope this helps
Mar 05, 2010 | 1992 Oldsmobile Cutlass Ciera
Location of the brake fluid input
the brake fluid resivoir is above the master cylinder on the firewall. so on the left side near the windshield. the power steering resivoir is closer to the front end and is distinguished by not being connected to the master cylinder..
Feb 08, 2010 | 1987 Mercedes-Benz 300-Class
2003 ford focus a rubbing/moaning noise when turning the wheel in either direction. even with car off and in park
sounds like it is low on power steering fluid.. Wen you top off the resivoir the car has to be runing to check the proper fluid level. Oh ya dont use any thing but power steering fluid.
Feb 03, 2010 | 2003 Ford Focus
Power steering pump is making noise. resivoir is full . do the lines ever get clogged?
Power steering pumps do give up.If its a whirring/buzzing sound whilst you turn the wheel,it is a good sign the pump needs to be replaced.Exchange units from a power steering/transmission shop is usually the cheapest way to go and not a dealer.Hope this helps you
Nov 11, 2009 | 1997 Chrysler Sebring
Power steering fluid
the power steering resivoir is located onto of the power steering pump, which has a pully driven by the belt(s). the resivoir is small with a cap the unscrews and a mini dipstick attached to the inside of the cap.
Jun 20, 2009 | 2000 Mitsubishi Montero Sport
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
