Question about Ingersoll Air Tools & Compressors
Over 110cfm,oil coming through air line - Ingersoll Air Tools & Compressors
  • 2,510 Answers
This is strange, compressors would normally pressurise the crankcase when rings wear, and you could possibly get water in the oil. About the only thing that could get oil coming out of the airline is if the compressor oil level is too high or it has been pushed up by water finding its way into the crankcase. What should then be coming out of the line is a mixture of oil and water. Is the tank water valve drained regularly?
Posted on May 26, 2011
Siegler oil stove
You need to bleed air from line, look for bleeder screw and unscrew while trying to start unit. Don't unscrew all the way, when oil comes out, screw back in and unit should start. Screw should be on filter housing and one on burner motor (where fuel line comes in).
Apr 23, 2014 | Heating & Cooling
1996 Kawasaki VN 800 Vulcan Classic oil getting into the air cleaner
Hi, Bernard and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Advice please Oil leaking out Air filter cover Kawasaki Vulcan Forum...
Oil in air cleaner cover
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Sep 11, 2012 | 1996 kawasaki VN 800 Vulcan Classic
I have a worthington tow behind compressor, and I have a ton of oil mixing in with the air, it makes a huge mess. I have replaced the filter, any other suggestions
you stated you replaced the filter.Was it the separator filter? the separator filter is located inside the separator tank. the separator tank is where you add oil. If this filter is bad it will cause oil and air to mix and get into the air. Also there is a 1/4 inch line that comes from the top of the tank . this line has an orffice in it If the orffice plugs oil can carry over into the air.
Sep 18, 2011 | Worthington Air Tools & Compressors
SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320 CFM i CONTINUE TO ADD OIL GOES OUT ON HIGH AIREND TEMP. SOMEONE TOLD ME THERE WAS AN ADJUSTMENT FOR THIS. CAN YOU TELL ME WHAT TO...
Mike, an EP 75 Should not use more than 3 to 5 parts per million of oil. Your oil issue sounds like you have a separator that needs replacing or a plugged scavenge line. The separator is located in the oil tank. the scavenge line and orifice come from the bottom of the separator filter to and Thur the oil tank lid. then to the air end. In this line approx. 1ft from the lid should be the orifice. make sure its clean. your high air end temp can be from several different problems. 1- low oil level from separator or scavenge line plugged. 2- A plugged oil cooler. Dirt and debris pushed against the cooler by the the cooling fan. This needs to be cleaned using a pressure washer. Wash in the opposite direction of air flow. Be careful with the pressure washer. You can damage the cooler. Low oil level and dirty coolers are the most common problems when getting high air end discharge temp shutdowns. However you could also have a bad thermal valve located where the three cooler lines come together. you will have to remove one line and 4 bolts. inside is the thermal element. You may also have a bad HAT switch (high air end temperature). It is located in the end of the air end and simply unscrews. I do not know of any adjustment.
Feb 12, 2011 | Air Tools & Compressors
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
Oil coming from line from engine feeding into air
More than likely your air filter is clogged and needs replacing. If that is the situation the carb needs air and is pulling suction on the crankcase breather tube siphoning up oil instead of just burning the vapors. If it was a busted ring the oil would be coming out the exhaust and burning blue smoke.
May 01, 2010 | Mtd 22" Yard Machine Push Mower
Air Tools & Compressors Logo
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
