Question about Watches
How many times to wind my oris big crown pointer date watch.The best time to wind it Is it in the morning or night,as i'm not wearing it while sleeping.
4 Suggested Answers
  • 2501 Answers
SOURCE: Omega constellation self winding watch stops
Omega claim that your watch will run for 40 or more hours, so stopping overnight should not happen. I doubt if you need to be particularly active to wind up the watch, otherwise this would make the problem quite common. My one experience of owning an automatic did not raise this sort of problem.
Discuss your problem with your supplier and describe your use. As you correctly say, having to hand wind i defeats the point of buying an autoamtic. (It could be that you have been sold two duff watches, however unlikely this may seem, it could happen).
Posted on Jun 06, 2010
mantis480
SOURCE: Oris dive watch
http://www.oris.ch/services/dis_manual.aspx?ln=en&page=0
Posted on Jun 13, 2010
  • 906 Answers
SOURCE: Oris Watches
good day,
hope this link below will solve your problem.
watches
Posted on Jul 30, 2010
Date changes at mid day not at mid night.
Your watch is 12 hours out of step.The date changes ever second rotation of the hour hand.
If you advance the time 12 hours, the date will change at midnight.
You may have to re-set the date.
Sep 16, 2011 | Tissot PRS 200 Wrist Watch
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
Cant set wrist watch
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
Winding and setting the time on a rolex watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Apr 04, 2009 | Rolex Watches
How do i wind and set my Rolex Oyster Perpetual watch
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
Apr 04, 2009 | Watches
How do I adjust my time
hi friend,
i think your rolex watch must be a automatic one. this kind of watch, you don't need to put battery, after in full power, i can last 24-48 hours. if you wear it, it will not stop, but if you don't wear it for long time, it will stop automatic. to adjust the time, you just need to wind the crown counterclockwise, and then pull out the crown, and then you will hear the sound of "click" and then find the right position, and then wind the crown to change the date. please note that the date have to change from small number to big number. after adjust it, you have to screw down the crown to a good water proof capability.
source form: Swiss ETA watch
Sep 30, 2008 | Watches
Breitling navitimer watch
breitling navitimer, keeps perfect time on the desk, but when ion the wrist it runs fast, as much as one hour in 24 hrs
Aug 03, 2008 | Breitling Hercules 246/GRY/PROF
Watches Logo
32 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
