Question about Philips Magnavox MWR10D6 DVD Recorder
About finalizing once a movie has been finalized can you add more stuff to the movie you put on the dvd or is it locked forever then?????
    Problem Solver:
  • 18 Answers
Once a DVD+R or DVD-R has been finalized, it cannot be edited again. You are stuck with whatever you have. On the other hand, you have to finalize the disc to make it playable on other DVD players.
The exceptions are DVD+RW, which, according to the manual, does not have to be finalized, and DVD-RW, which you can "Undo Finalize" in the "SETUP/Disk Edit" Menu
Posted on Aug 19, 2008
    Problem Solver:
  • 5 Answers
Use only the dvd-rw,they are so much easier and you dont have to finalize them,
Posted on Aug 20, 2008
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Vcr/dvd when can i finalize my disc iam recording i have a magnavox combo before i starte or after tapeing
Finalizing means that you're finished and you won't be putting anything else on the disc. Finalize it after you're done so it will play on other DVD players. If you have a rewriteable DVD, then you can go back and erase it and record over it later even though you've finalized it. If you have a -R or +R only, then you can't and whatever is on it when you finalize it will be on it forever..
Dec 08, 2009 | Philips Magnavox DVD/VCR Dual Player
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
INCOMPATIBLE DISC
Good news.. you should be able to put the disc back in to the device that you recorded in on... and go to the menu to do the finalize... in fact, you may be able to add more to you disc prior to the finalize process if you want...
once it's finalized you should be able to view on other equipment... your files should all be there as well.
Let me know how you do!
May 26, 2009 | Panasonic VDR-D300 DVD Camcorder
Finalize a Disc on Mangavox MWR10D6
No. Generally finalising just writes the unused spaces as unused so the player knows and adds a stop code. The shorter the DVD the longer the finalise. An hour and a half on two hours is plenty of space.
Apr 13, 2009 | Philips Magnavox MWR10D6 DVD Recorder
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD will not finalize
Try this. In your SETUP options, ensure that AUTO FINALIZE and FINALIZE AT END OF TIMER are turned OFF.
Insert DVD to be finalized. Press SETUP button. Be patient. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point. Picture quality is as good as the expensive DVD's.
Aug 19, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a DVD recorder that I used to record all of my old VHS tapes to DVD.I used the proper DVD's that my manual said was compatable with the recorder- DVD R.Now when I go back some time later to view or...
Sounds like you may not have finalized some of your DVDs.
ALSO once you finalize a DVD-R concider it a full disk, you cannot add to a finalized disk. In the future if your recorder can use DVD+RRW you won't need to finalize, and you can add to +RW disks
Jun 30, 2008 | Televison & Video
How to finalize a dvd on philips 3475
For my Magnavox, this work:
May 27, 2008 | Philips Magnavox DVD/VCR Dual Player
Finalizing a dvd
Insert DVD. Press SETUP button. Be patient. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it much cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point.
Dec 19, 2007 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MWR10D6 DVD Recorder Logo
264 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
