Question about Gestetner C7417 Laser Printer
My Printer Aficio C7417n is displaying error SC486
Open the front door , The blue clips {} on each side
hang them up and remove the paper which stucked into your printer
then put down the clips
and close the front door
it's done 4 me , hope it'll be the same for you
and sorry for my bad English :)
Posted on Jan 10, 2013
2 Suggested Answers
  • 903 Answers
SOURCE: printer jams when printing and I ricoh cl2000n
sc486 is a solenoid error with the black drum unit. The most likely culprits are a bad engine board and a bad drive unit, neither one of which is cheap unfortunately. You should contact your local service technician and have them take a look at the printer to see which component is causing your problem.
Posted on Dec 19, 2010
Why does error sc486 power off/on occur when printing
Something inside printer is blocked. There is a magnetic clutch that sometimes could be a reason. Check that Waste Toner bottle is not full because in that case many bad things can happened.
I can tell you this for sure:
it's time to replace the printer with new one!!!
Maybe you will be able to buy cheep SPC410, SPC420. They are perfect
May 21, 2014 | Ricoh Aficio CL2000N Laser Printer
Sc-486 on the Ricoh Aficio CL3000 printer
sc486 is a problem with either the engine control board or the drive unit, or the connection between them. One or the other will probably have to be replaced, depending on exactly what's causing the problem.
Mar 22, 2011 | Ricoh Aficio CL3000 Laser Printer
Code sc486
BK Solenoid Error : The BK solenoid cannot drive the black PCU
Engine board or Drive unit is probably broken
Jan 22, 2011 | Ricoh Aficio CL2000N Laser Printer
Printer jams when printing and I ricoh cl2000n error code sc486
Dec 10, 2010 | Ricoh Aficio CL2000N Laser Printer
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there...
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
Oct 06, 2009 | Ricoh Aficio AP410N Laser Printer
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh CL2000 SC486
Realizar a troca do BK Solenoid.
Ele está localizado dentro do driver onde estão as engrenagens, ao lado esquerdo da impressora atrás da placa BICU
May 21, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Gestetner C7417 Laser Printer Logo
749 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
