One or more activex controls could not be displayed either 1) your current security settings prohibits running activex controls on this page or 2) you have blocked a publisher of one of the controls
  • 629 Answers
Try to adjust your browser security settings to low or medium low and set the active X controls to prompt so yuo can have the option to select to accept or decline one when needed. be sure to clear browsing history as well after making the changes
Posted on May 26, 2011
Running Windows XP Problem with HP Director Every time I try to open it an error message pops up that says... One or more ActiveX controls could not be displayed because either: 1) Your...
Upgrade from director to solution center.
With the limited information you have given, that's the best advice I can give off the top of my head. Director is old, solution center is current.
Mar 17, 2011 | Computers & Internet
HP Precicionscan Pro 3.1 now starts with this error message: \r\n "One or more ActiveX controls could not be displayed because either: 1) Your current security settings prohibit running ActiveX...
http://support.microsoft.com/kb/907343
You receive a "Your current security settings prohibit running ActiveX controls on this page" error message when you start Project or Project Web Access
Mar 05, 2011 | HP Scanjet 5400c Flatbed Scanner
I am getting the following message when starting MGI photosuite 4 One or more ActiveX controls could not be displayed because either: 1. Your current security settings prohibit running ActiveX controls on...
When ever you buy software from now on make sure it runs on a 64 bit platform or you can get drivers for a 64 bit operating system for the hardware
Feb 06, 2011 | Computers & Internet
I got a Sony Bloggie Touch MHS-TS10 for Christmas. I am on a Gateway computer running Windows Vista Home Premium 32bit. The camera works fine, but I can't install the software! When I try, I get this...
i had the same problem about the active x controls to solve it, browse the bloggie_sw unit (in my laptop its i:) then look for a carpet labeled conf , open it, you should find a setup.exe file, open it and install it, i did have a problem about a config file beind damaged, just tell windows to fix it clicking on that option then the bloggie software will be installed. i worked for me hope it works for you
Dec 26, 2010 | Sony HD Touch Camera MHSTS20S
When start HP director on WXP a message window opens: "One or more ActiveX controls could not be displayed becose either 1. Your current security settings prohibit running ActiveX controls on...
Cause:
This issue occurs if the following conditions are true:
  • The Project Guide is enabled.
  • Security settings for the Local Machine zone are configured to prevent ActiveX content from running.
Note The security settings for the Local Machine zone control the browsing of local content in Windows Internet Explorer. The Project Guide is an Internet Explorer page that displays in Project.
Resolution:
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. Please Click the link below to know how to back up.
http://support.microsoft.com/kb/322756/
To resolve this issue, use one of the following methods.
Method 1 loadTOCNode(2, 'resolution');
  1. Click Start, click Run, type regedit, and then click OK.
  2. Expand the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0
  3. In the right pane, right-click 1200, and then click Modify.
  4. In the Value data box, type either 1 or 0 to overwrite the existing value of 3. Then, click OK.
    Note If you type 1 in the Value data box, you will receive the following prompt when you start Microsoft Project: Do you want to allow software such as ActiveX controls and plug-ins to run?Additionally, you will receive this prompt at other times when you use Microsoft Project. If you do not want to receive this prompt, type 0 in the Value data box.
    The values 0, 1, and 3 are associated with the following behavior:
    • 0 = Enabled, or the action is permitted
    • 1 = Prompt
    • 3 = Disabled, or the action is not permitted
  5. Quit Registry Editor.
If this issue still occurs after you perform this procedure, your administrator may have set a policy that prevents ActiveX content from running in the Local Machine zone. We recommend that you contact your administrator to configure the settings for the Local Machine zone. For more information about the Microsoft Internet Explorer security settings that cause this error message, click the following article number to view the article in the Microsoft Knowledge Base: 833633 (http://support.microsoft.com/kb/833633/ ) How to strengthen the security settings for the Local Machine zone in Internet Explorer
Method 2 loadTOCNode(2, 'resolution'); Turn off the Project Guide. To do this, perform one of the following actions, depending on your version of Project:
  • Project 2007
    On the View menu, click Turn Off Project Guide.
  • Project 2002 and 2003
    On the Tools menu, click Options, click the Interface tab, and then click to clear the Display Project Guide check box. Then, click OK.
Dec 24, 2010 | Computers & Internet
One or more ActiveX controls could not be displayed because either: 1) Your current security settings prohibit running ActiveX controls on this page, or 2)You have blocked a publisher of one of the...
Please help. My HP scanjet G2410 gets message such as this:
2)You have blocked a publisher of one of the controls.
As a result, the page might not display correctly.
I've already done uninstalling and reinstalling the driver.
Dec 21, 2010 | HP Scanjet 4370
I use outlook 2003 and this error msg. for the first time today, I get the error message when replying or forwarding and email: One or more ActiveX controls could not be displayed because either: 1) Your...
ok well its what it is sayin , i will bet if you go into your setting your active x controls are not clicked, and if its the sending look at your spam controls i will venture a bet the sender is on your blocked list. or a known spanner that your anti virus is blocking.for active z goto
open ie, goto top of page and select tools, internet options, then advanced scroll down and look for the word active x , and click it on . turn off machine and reboot.
Mel
Jun 02, 2010 | Microsoft Outlook 2003 for PC
ActiveX Control problem in QuickBooksPro2007
It seems that you are not able to run activex control because of high security settings on internet explorer.
open internet explorer, go to tools and then click on internet options.
Go to security and change the setting to medium or low which should allow the activex to download
Jul 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
URGENT - Windows XP Home edition -ActiveX Control problem -URGENT
The Lookout Web Client is implemented as an ActiveX Control. ActiveX Controls can execute any code on a local computer from a webpage (they can even delete files), so you should always be familiar with the origin of the control that is being loaded. There are two types of ActiveX Controls: unsigned and signed. Signed controls keep information about their origin (see the last picture below), while unsigned controls do not. Because the signing technology guarantees that the signature cannot be falsified (e.g., by a hacker), signed controls are usually considered safe.
Lookout 6.0 and higher uses a signed web client ActiveX control and is considered safe by Internet Explorer under the default settings. If the security settings have been changed (either by the user or system administrator), follow the procedure below.
Lookout 5.1 and earlier uses an unsigned web client ActiveX control. By default, Internet Explorer prohibits downloading and running unsigned ActiveX controls on your computer for security purposes. If you are familiar with the download, then you can relax the security settings.
  1. In Internet Explorer, Go to View (or Tools) » Internet Options » Security » Trusted Sites
  2. Click the Sites button.
  3. Enter the URL of the Lookout Web Client.
  4. Deselect Require server verification (https:),
  5. Click OK to return to the Internet Options.
  6. Make sure that the Trusted Sites security level is set to "Low".
    • If you do not see the slide bar for the level, click the Default Level button.
Or Try This
To resolve this issue, unregister the Comcat.dll file by using the Regsvr32.exe utility with the /u switch as in the following example: regsvr32 /u C:\winnt\system32\comcat.dll and rename the Comcat.dll file in the %SystemRoot%\System32 folder.
After you unregister the Comcat.dll file, reinstall Internet Explorer.
For information about how to rename a file, click Start, click Help, click the Index tab, type renaming, and then double-click the "Renaming files" topic.
If you remove Internet Explorer before you reinstall it, be sure to rename the Comcat.dll file after removing Internet Explorer.
Feb 06, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
