Question about Canon PIXMA iP4300 InkJet Photo Printer
Printer will not even turn on the power supply cord is fine.
  • simek_pv May 26, 2011
    Thank, but to insurance policies I can not get it to be a special wrench or screwdriver
    Scholar:
  • 157 Answers
1.Make sure powerchord connected properly&turn the switch ON.
2.Fuse has damaged due to excess/Voltage variations(inside Printer Board),you have to replace the fuse.
Posted on May 26, 2011
No Power. Blown fuse or dead power supply?
Replace the power supply. Definately not the fuser
Jul 23, 2017 | HP LaserJet 1200 Printer
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
Canon h12256
most likely the power supply is blown next time get a power surge...try replacing the power supply or take it to a printer fix shop
Sep 24, 2013 | Canon imageCLASS D320 All-In-One Laser...
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
No power to printer even though it is plugged in to wall outlet???????
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, check the power cord. Most times, a bad power cord causes this kind of problem. But if the power cord is not the cause of the problem, then problem must be from the power cord inside the printer.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Jun 03, 2011 | Canon PIXMA MX860 All-In-One InkJet...
X4530 InkJet Printer: printer won't turn on. Don't have ink cartridges i...
The printer should turn on even without the cartridges yet. Try this. Make sure the power cord is plugged in straight to the wall. Bypass any surge device or power strips. Unplug the power supply from the printer. It's the black box behind the printer where the power cord is plugged in. With the power cord still plugged in to the power supply, the LED around the contacts should lit solid green. If not, make sure the power cord is properly secured. If this does not help, you may have a defective power supply. If it does, insert it back in the printer in the correct position. Plug it hard just to make sure. If it does not power on automatically, press the power button. If this does not help either, I strongly suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 18, 2010 | Lexmark X4530 InkJet Printer
Will not turn on even tho plugged in
Try a different power cord or test the power cord on a different piece of equipment.
If it still does not work then the printer has a power supply problem and needs to be repaired or scrapped. A new printer may be a better cost effective solution.
Unless you have electrical knowledge I suggest you do not try to fix mains powered equipment. Mains voltage is dangerous.
Mar 06, 2010 | HP LaserJet 2605dn Printer
My HP Photosmart C4480 will not turn
If you are confident with electronics, remove the rear casing near the power socket, and check the power supply board for a fuse. Using an exact match, replace the fuse and replace the cover. Try powering up. If it fails, you have a blown power supply :(
Mar 05, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Bought a display model of the pixma mx700 series
1. If you bought it from a store bring everything back with receipt and tell them they need to correct the problem.
2. You lucky you even got a power cord what brand of printer is it. Most company's don't even supply a power cord with the printer.
Jan 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Hp photosmart c4580 won't print
Your problem indicates that your printer is not getting the power supply .
  • Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
  • If the power cord is not damaged, plug the power cord into a different electrical outlet without using a surge protector. The product power light should turn on.
  • If the product power light does not turn on, the power cord should be replaced.
Dec 09, 2008 | Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
968 people viewed this question
old marine
old marine
