Question about Behringer V Tone GMX212 2X60 Watt Stereo Guitar Combo (Standard)
I need to know the part number for the main input jack on the front of the amp.Also what supplier would have this part? I'm finding it difficult to track down someone who can help!
  • Behringer Master
  • 5,603 Answers
To get the official part number for the jack you have to call Behringer at 1-425-672-0816 to get the number AND an incident number. You can order the part from the only Behringer distributor, FullCompass.com. If they don't have it in stock expect to wait months. You can also try this company which may no longer be the main distributor:
http://www.dbmproaudio.com/behrparts.html
Posted on May 26, 2011
  • secondcha880
    secondcha880 Jan 14, 2013
    I just called the 1-425-672-0816 number and these folks have the jack in stock for like a buck something but the input board is out of stock but on order. The board goes for around $5 and supposedly includes the jack. Anyway the guy was really cool and helpful and said to try back to see if they have an ETA for the boards. $6 shipping for anything under $45.
Where are the main speaker cables connected to in a behinger europower pmp 2000 mixer amp
The Behringer PMP2000 uses Speakon jacks on the speaker cables. The outputs are located on the back panel. Which ones you use is determined by how you configure the mixer. The Main inputs are located on the right side of the face of the mixer.
Dec 31, 2014 | AMP Music
Have a marshall mg250dfx from usa so it is 110 v but i'm over seas and I use it with a step down transformer 220in-110out and it worked perfectly for some time but today wile i was playing it started...
Assuming the power in is good (I would check that first though, AC voltage going into the amp), then plug a patch cord(any 1/4" to 1/4") cord into the effects loop on the back of the amp and insert and remove a plug into the headphone jack a number of times to clean the contacts(headphone jacks and effects loop jacks are normally switching jacks that pass audio when not in use). Still not working?... If the pots(gain, volume and tone controls, etc.) are scratchy that could be the issue. The input jack could be the cause(damaged, cracked solder or circuit board trace). Wiggle the input jack to see if that causes or corrects the problem. A little WD-40 works wonders on correcting dirty jack issues. If none of the above are the cause then it is likely a cracked solder joint, trace or component lead which would have to be resoldered/repaired (maybe dirty contacts between the small effects board and the main board). Also watch the overdrive channel LED when the audio drops. If the LED goes off could be a power supply issue or a channel switching issue. Tapping on the amp will help indicate bad connections, cracked component leads or damaged traces.
Jul 03, 2013 | Music
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Oct 29, 2012 | Behringer Music
I need to replace my Input - jack, in my Nashville - 112 Amp !!!
Replacing jacks is not that difficult, even with one that is made different from the original. Just make sure you have the same length as the original and the same number of contacts. You can salvage one from soemthing else, like an old tape deck buy one off ebay or buy one from a supplier like Mouser or Digikey. http://www.mouser.com or http://www.digikey.com
Use an ohm meter as you go to make sure you get the input connected to the right tab of the new one.
Jan 29, 2012 | Music
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I just wanna check was my little mark 250, older version, ever been opened or changed in any way. I was at the guy that opened it and told me that because of the input power of transformer that is about...
when using amps,, you can't go by the number of the amp to determine what wattage the unit puts out, after checking on this amp,, the white marks that your seeing on the cable, is probably just some of the thermal paste that you apply to any heatsink or CPU ,, nothing to worry about, now as far as the wattage,, here is what they say about that amp, so there is a difference between the 4 and 8 ohm set ups
The Markbass Little Mark 250 bass amp head is a high-quality bass amplifier with a solid-state preamp and an analog power amp. The Little Mark 250 delivers 250W of power into a 4 ohm cabinet, or 150W into an 8 ohm cabinet. This Little Mark has a 4-band EQ, Markbass' VLE (Vintage Loudspeaker Emulator) and VPF (Variable Pre-shape Filter) filters, as well as both Gain and Master volume controls. The front panel accepts both a passive or active bass 1/4" input, as well as a balanced XLR input for acoustic bass pickup systems or a microphone. On the rear panel you'll find a Neutrik Speakon combo jack output that accepts both Speakon or 1/4" speaker cable as well as a second 1/4" speaker out jack. You'll also find a balanced XLR out, unbalanced tuner out so you can tune as you play without passing your signal through pedals, and a Send and Return Effect loop which saves you from losing your signal if one of your pedals dies or a cable in the chain gives out.
Aug 02, 2011 | Markbass Little Mark 250 Bass Amp Head
Okay i need to know how to get inside my amp to tighten up my input jack cause i cant play at all on my amp cause i cant get inside it i took off all the screws in the back and trying to get it off is a...
One can overtighten the input jack and "un-rivet" the jack. They are not made very well !!! OFTEN when they appear loose, they HAVE un-riveted the threaded sleeve from the metal inside the jack... that USUALLY requires REPLACEMENT of the jack itself.
The cabinet backs on a lot of these have to be PRIED out as the Tolex covering often makes them tight.
The amp portion is often retained by screws from the top and or sides AND even the two holding the handle on... there are many different configurations. Sometimes the amp comes out the front, sometimes the back. It is easy to shear off the speaker wires when removing some of them.
Dec 18, 2010 | Marshall 15 Watt Guitar Amp
Korg Kaoss Pad 3 1/4" mic input is shot, need repacement
If you can unsolder the jack, take it to any good electronics supplier and they should be able to sell you a replacement. The manufacturer is not as important as the pin configuration and the height it stands from the surface of the circuit board.
May 05, 2009 | Korg Mini Kp Kaoss Pad
Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
Mar 10, 2009 | Music
Behringer V Tone GMX212 2X60 Watt Stereo Guitar Combo (Standard) Logo
227 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
