I have just purchased a sharp HT-SB250 sound bar to go with my sharp 32" Aquos LED tv. The item came supplied with the RCA cable and having connected it to the sound bar and the audio connections in back if tv, there is still no sound, if you turn up the sound on the bar you can hear alittle fuzziness but no sound, the remote with the bar changes the functions/tv but there is no sound from the bar......
    Master:
  • 586 Answers
You have obviously connected the sound bar's RCA (red, and white) cables to the TV's IN jacks rather than the OUT jacks, OR you might have them connected to the RCA VIDEO jacks. Check it. Connect them to the TV's audio OUT jacks. Presumably, the inputs on the back of the TV are marked "audio out", and the IN connections from your sound bar must go into the OUT inputs on your TV. I can't imagine what else it could be causing the problem.
Posted on Jul 26, 2017
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
lynchms
  • 93 Answers
SOURCE: connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Posted on Feb 28, 2009
SOURCE: YAMAHA RX-V1800 no Sound
There is an HDMI setting that should be set to through instead of rxv1800. See page 88 of the manual
Posted on Oct 03, 2009
gopakumarg43
  • 75591 Answers
SOURCE: i have a sharp aquos
Hello
What is the probelm do you face with your Sharp HT-SP300. Give me some more details by Fixya please. OK.
Posted on Mar 11, 2011
  • 5481 Answers
SOURCE: Hi.How can I connect SHARP HT-SB400 sound bar
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Posted on Mar 05, 2012
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Dec 02, 2014 | Samsung Televison & Video
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
I just bought the sharp home theater system ht-sl70/ht-sl75 and I cannot get the volume to be controlled thru my remote. I have a 60 inch sharp aquos tv. It has no arc and when I use the rca connection it...
Hi
I just bought HTSL75 speakers. Its manual saying its volume is controlled by TV's remote control
But i am having Samsung UN46EH6000 LED. and Speakers is connected to LED via RCA and LED is giving fixed output, so all the time, speaker is working on full volume
Is there any workaround, so that i can control volume while using sharp HT-SL75 speakers with Samsung UN46EH6000 ?
Is there any volume control device to control the volume of the speakers in my case ?
Thanks for your help !!
May 09, 2012 | Sharp Audio Players & Recorders
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 32" aquos LCD tv, will not power up with remote or switch on set, has power (120v) to end of cord where plugs into back of tv
This is usually some sort of power supply shut down problem the TV has detected a major fault, and has shut down the power supply to avoid a fire or explosion.. you need to get this unit serviced by a reputable repairer also always ask for a 'Quote: so you know weather to repair or replace.
Mar 21, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Blinking led
Free diagrams unlikely to be available take the board's out and check for blown capacitors following good antistatic procedures and decide from there
Or find a good independent repair specialist to do the work and set your self a budget
My sharp aquos stopped working with a blinking power light £2000 was the repair quote for a new board and LCD panel for a £699 TV after they tried the capacitor replacement
Jul 01, 2017 | Sharp AQUOS LC-40C32U 32 in. LCD TV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
155 people viewed this question
 Grubhead
Grubhead
