Question about Water Heaters
I have a Baxi Combi 105 HE, the past few days it won't heat the water. The central heating comes on fine. The kitchen tap won't heat up at all unless the bathroom tap's on at the same time. The bathroom water normally heats up but not everytime. The only way I can guarantee hot water every time is if I put the heating on first. The light doesn't even come on to show that hot water is being asked for. There are no fault lights flashing. The boiler was installed 2005 and has never had any problems.
5 Suggested Answers
  • 3 Answers
SOURCE: combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Posted on Dec 30, 2008
zeusfaber
  • 247 Answers
SOURCE: Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Posted on Feb 03, 2009
  • 30 Answers
SOURCE: re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Posted on Mar 30, 2009
mrhotandcold
  • 248 Answers
SOURCE: Manual for Baxi Boiler
any merchant will get one mailed out to you
Posted on Nov 06, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Re: combi boiler.
Mar 23, 2009 | Water Heaters
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Combi cutting out and overheating
Dec 22, 2008 | Water Heaters
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
70 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
