Dear Sir, I ahd problem for the printer, Since it has been two weeks. I need to get it solve soonest. Caued we have data sheet to be printed. We need hlep now .Could you help us on this please. I have several in day and I have receieved any calls. I only get a reply after many e-mails sent sent to your department. My case no: 4629443089. As a cutomer do you have any advice.
  • 31 Answers
HI,
you better go for a laser printer's,Hp groups or canon group ,then it will be ease for you to get printout without trouble.
You didnt write the exact technical snag ,you were faced while taking out prints.
to print Data sheet ,even dot matrix groups printers are also convenient,
Posted on May 26, 2011
Printheads in Designjet 510
Alexander, did you do the allignment after changing print heads?
Feb 01, 2014 | HP "designjet 510 24 in. inkjet printer"
Cannot print from the note pad
You need to make sure your note pad is not too (thick) and also
that it is the correct size of paper and not too small,(tip) sometimes small sheet can be attached to full size sheet to enable printer to print.
Nov 14, 2013 | Intermec PC43t
I have an HP PHOTOSMART C4680!On the screen it apears "Cartrigde problem" and the button is blinking!What can I do to fix the problem?
1.Remove the ink catridge
2.Replace properly
3.try to print
4.if even same problem will be occured then replace with new catridge.
Note: Hp printer come along with a software cd.it has the driver for printer,troubleshooting and maintenence software.in the trouble shooting guide will help to removes and replaces the catridge properly.Also a Quick start guide(A printed sheet) also can help.
5. if Even the problem not solved then unsqurew the printer squrews carefully ,
6.look at the mechanisim if any damaged
7.look any Data cable or Power cable may be damaged (Cables are looking like a white color mica ribbon)
Thank u sir ... All The Best....
Apr 22, 2010 | Office Equipment & Supplies
Printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Aug 13, 2009 | Epson Stylus C88 InkJet Photo Printer
HP Laserjet 1300 is printing many pages on one sheet
Sir,
Try to re-adjust the cartridge or reinstall the catridge it will solved
Thanks Good Luck
Jul 21, 2009 | HP LaserJet 1300 Printer
Print error code 021
1. The print job was too complex for available printer memory. 2. Press GO to resume printing.
3. If you lose some data, you might need to add more printer memory.
4. For a temporary solution, simplify the image or print at a lower resolution.
Jul 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Intermittantly Prints pages of ascii characters
Check your USB or Parallel cable what you are using. If not solved connect the printer to another pc . Some times computer port may get damage.
Jan 14, 2009 | Brother HL 5250DN Laser Printer
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Jan 16, 2008 | HP LaserJet 5L Printer
49 people viewed this question
jasbo
jasbo
