I press on on the remote but the unit does switch on, I have replaced the batteries but still no go
    President:
  • 1,216 Answers
First you need to check whether the remote is fine or not.if problem not with remote , then Sounds like either a wiring issue (doubt it) or possibly need to get your pcm reflashed at the dealer.
Posted on May 26, 2011
What remedy to turn the unit operational
Check the batteries of your remote control, replace the batteries, press power button. You should hear a click from the unit. If no sound from the unit, check if there is power going to your unit. If no power, reset the breaker by pulling the handle to off position and then switch it on. For disconnect switch replace the fuse and then switch it in on position.
Mar 04, 2016 | Heating & Cooling
Buttons on remote must be pressed hard to work>
There are a number of problems that could cause the issue you describe. A weak battery could be the culprit. If changing the battery does not resolve the issue then some type of substance may be on the contacts of the buttons. The keypad of your remote is a series of simple switches that when pressed function according to the programming of the remote. Spilling something on the remote and then having it dry up could leave a film on the switches that would make it difficult for the contacts to close. By pressing harder you are forcing enough of the switch to make contact that it will finally function. If the remote is in a room where people smoke this can also leave a film on the contacts and subsequently make it necessary for you to press the keys real hard to make them work. Finally, the keys themselves will wear out over time, and it will then become necessary for you to press them real hard before they will function properly.
If changing the battery/ies does not resolve the issue then your choice is either attempting to clean the remote, or replace it. Many remotes are difficult at best to take apart. The keys and switches are quite small and can be very difficult to try and clean without damaging them. If your remote uses the micro switches instead of the switch array it is impossible to open them up to try and clean them out. At this point you would be better off checking with your local electronic repair center to find out how much a replacement remote would cost. Depending on the age of the remote you might not be able to get a replacement. You would then either have to put up with pressing down hard, or look at possibly replacing it with one of the programmable remotes that are now available. Should you choose this route check with either the manufacturer's website, or your local store. to ensure that the universal remote will indeed properly control all aspects of the unit you want to control.
May 15, 2011 | RCA Televison & Video
No response when remote control buttons are pressed.. I put new batteries. but not work..
Does the unit work from its onboard controls or is this only a remote control failure?
If the latter...
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Apr 23, 2011 | Panasonic SC-PT464 Theater System
My samsung remote BN59-00852A just stopped working, it wont control the tv. i changed the batteries but still nothing. please help
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Feb 03, 2011 | Samsung BN59-00599A Remote Control
A light bulb in my ceiling fan burned out the other night when I turned it on with the remote. I changed the bulb, but since then the remote will not turn the light on or off. The wall switch will, and...
Sometimes all you need to do is switch the wall switch on and, off a few times while you press the lamp button (off press the button then: on press the button) no go? then: check or, replace the hand remote nine volt battery. still no go? then:
Check the wattage of the replacement bulb; some high wattage bulbs will rob power from the remote unit. didn't work? OK,
next turn off the power to the lamp and, open the lamp cover: you will see a large plastic rectangular box (the reciever) open the cover on the box and, you will see a block of tiny switches then: open the hand remote battery case it too will have a block of tiny switches these must match i.e. 1,3,5,= on 2, 4, = off both the remote and, reciever box. Barring that ...you'll need a new reciever for your fan.
Jun 01, 2010 | Hunter 27187 Remote Control
Remote stopped working
Try the buttons on the TV to verify that the set is working. Then;
If you are still having problems, you may have to replace the remote.
Mar 16, 2009 | Sharp LC-32SB21U 32 in. LCD TV
My volume control on remote doesnt work its a dynex zrc-102 remote control how do i get a code or what do i need to do so i can ajust my volume from my remote control
Try the following first;
If you are still having problems, you should return the unit to the place of purchase for a replacement.
Mar 13, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Trouble switching on my Sagem 6200T PVR.
Hi margaretanne on Dec 02, 2008
I have a similar problem with mine. I find the battteries are loose, I remove the back of the remote, jiggle the batteries and press the button, and it works, until I drop the remote and the batteries loosen again.
Dec 02, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
