Question about LG Dishwashers
LG LD1415m 5 minutes into the cycle an error comes up E1
  • LG Master
  • 19,396 Answers
Hi.
E1 means that there is water leakage from hose connection, or that there is leakage because one part is broken. In simpler words it means that the machine detects incorrect pressure and amount of water because of a fault or because of incorrect hose settings.
Disconnect power. Check the plastic hose on the side.
Clean drain. Check the drain hose settings. Ensure that the drain hose is at the height specified on manual. Do a test running a cycle with the drain hose down in the bucket.
If hoses are OK, then problem can be hoses and seals connected to the motor. If seals are OK, then the motor must be replaced. Motor and seals are located behind the kick panel at the base of the appliance.
Regards.
Ginko
Posted on May 26, 2011
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Dishwashers
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Machine LD2131WH was in 5 cm of water but now water problem solved however machine keep giving code E1 even when taken of the mains for more than 30 minutes
Hi jwvdbok,
You are receiving the E1 error because the Circulation Motor is faulty. Please check my Tip below on how to repair it:
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 10, 2011 | Dishwashers
Have E1 problem,machine stopped running,replaced washerpump/motor,runs for a few minutes E1 comes up and machine stops,any ideas
I had the same problem, new wash pump didn't solve the e1 error. New capacitor did the trick. Hope this helps
Jan 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
E1 error
Called a repair man and 400.00 all fixed
Aug 03, 2008 | Dishwashers
Dishwashers Logo
313 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
