Question about Car Audio & Video
I am installing a new stereo in a 2006 Dodge Caravan & I cannot find the wiring color codes anywhere or find an adapter that will work plus I already started cutting sum wires. Can u help me plz
  • 62 Answers
Get on ebay and look up the wiring install kit for your van and enlarge the picture and write them down in reverse order. or just go to autozone or walmart and do the same
Posted on May 26, 2011
How me installin a new radio
Buy wiring kit and radio dash kit from parts store for the paticuliar vehicle remove old radio, splice wires from new stereo to wiring kit, they should be color coded, install radio dash kit plug in wiring harness slide stereo into dash and enjoy
Nov 06, 2013 | 2000 Dodge Caravan
How do ihook up a new car stereo to my 2000 dodge slt quad cab wit 4speakers with crossovers how do i find the wireing 4 all the audio systerm
Go 2 auto zone or any stereo shop and get a factory wiring Harness adapter 4 youre year and make it will plug in and Will be color coded and labled for easy install remember U will need a adapter plate 2 for aftermarket radio 2 fit Factory hole each will run u about $20.00
Jun 13, 2011 | 2000 Dodge Dakota Quad Cab
My car stereo was stole they cut the factory wiring harness from the durango i need to know the color codes of the wires please
That's hard to answer cause it depends on how far back on the wire harness they cut. Plus if you have a Bose system or not. I would highly suggest to take it into a stereo install shop to at least check it out but maybe install the new stereo.
There is a wiring color code that all vehicles use but if the wires have been cut to far back they will be different colors. If you have a factory amp then you will have to rewire for the speakers to bypass it.
I added below the color code. Make sure you disconnect your battery before you start wiring anything.
Please note: You can do major damage to your truck computer and other components if you wire it wrong.
Proceed at your own risk
moz-screenshot.pnghttp://i.ehow.com/images/a05/32/br/hardwire-car-stereo-800X800.jpg
Feb 26, 2011 | Dodge Car Audio & Video
I need a wireing diagram for the sterio for a 1997 dodge caravan
Will the color code do, or do you need the actual wiring diagram?
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
Sep 22, 2010 | 1997 Dodge Caravan
What is the wire color code for the factory installed stereo (radio) for a 1997 Dodge Caravan?
http://www.modifiedlife.com/1997-dodge-caravan-car-radio-stereo-audio-wiring-diagram/
hope this helps rate me pls
Aug 11, 2010 | Car Audio & Video
Im putting n a stereo but i dont no the color code
The stereo side of the wires should be labeled. Check out the12volt.com for a wiring schematic for the truck side. I advise against cutting and splicing wires for a stereo installation though. They make inexpensive harness adapters that will allow you to splice into the stereo harness without cutting into the factory wiring.
May 23, 2010 | 1998 Dodge Ram 1500 4WD
Radio: replacing radio,not stock,have adapter connector, when hooked up radio pwrs up,but NO SOUND,somehow in mute,took to the"radio doctor", radio tests fine,& he saw how I had it hooked up, extra...
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN
1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Aug 06, 2009 | 1998 Dodge Grand Caravan
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
Need wiring schematics for a 1996 dodge caravan stereo hooking a new one up but dont know what wire is what theres no diagram on the stereo
Save yourself some hassle & buy the adapter to go from Chrysler harness to generic, from same place as stereo or any auto parts place that sells stereos/radios, should have them.
Dec 20, 2008 | 1996 Dodge Caravan
Cd player instalation
Most stereo installation places have plugs that adapt your current harness to your new one. Take your new player with you to match up, it may save you a nightmare in wiring, for the sake of $20 or so.
Aug 02, 2008 | 1995 Dodge Stratus
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
