My ram is beeping how can i fix them - Computers & Internet
    Scholar:
  • 81 Answers
If 1 beep its - video card
if 2 to 3 beeps - RAM
if it beeps continuously - it the processor
REMEDY / SOLUTION :
1. (VIDEO CARD)- remove the video card clean it up... you can use eraser...make sure to remove the dust/lint .....
2. (RAM)- If the problem is the ram ... its the same.. remove the ram clean it..the same as you clean the video card...but if you put back the ram to the slot...make it sure to lock it up and tighten up..just monitor it that its not loosen...
3. (PROCESSOR) - remove the processor ... clean the white one i mean the paste
(thermal paste) then if you don't have that paste try to ask the hardware im sure they have one and grab it... don't leave the processor if it is not attach in the slot make sure to have that paste first it has time limit in exposing the processor it may cause a problem if the processor wont put back int the slot.. <the main solution is change the thermal paste then lock it up tightly.. the most important thing is just...lock it up so tight..>
that all...
this is only my suggestions ....
Thanks for rating
Posted on May 26, 2011
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
Computer Problem - BLACK Screen + BEEP BEEP BEEP BEEP how can i fix that
This issue is with RAM
You need open the cabinet and and clean the RAM terminals using cloth or rubber
then place the RAM on the slot and check.
If it is working then ok.
If not you need to change the RAM.
Nov 05, 2010 | Computers & Internet
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
No display, i have already change my ram, processor, power supply but no result if i pull my ram replay ram beep from motherboard
no display is basically ram issue but condition that mother give u beep noise,
refix RAM proprely, chaque SMPS , PROCCESSOR,HARD DISK, Fixed togethar again ok resolve issue.
Mar 17, 2010 | Intel 845GEBV2 Motherboard
Powers on, but screen is black It was left on and open a few inches while listening to music and it went black. When you turn the power on now it beeps a few times , nothing else
Dear friend you mention long beeps/few times beeps.
Its mean its RAM problem, Remove the ram from the ram slot & clean it by napkin & use a brash for cleaning ram slot. Then fix it back again. After that power on the laptop & see what's going. If the same sound again , that's mean the ram not working, its damaged. So buy/ arrange a working ram and fix it on the slot. Now power on and run the laptop for work.
Thanks & waiting for your reply.
Feb 05, 2010 | Fujitsu LifeBookS6120 Notebook
Does not accept any RAM, continous long beep
blow off the dusts from RAM slot and fix the RAMs,, if still continous the beep sound get new RAM and Fix it
Jan 18, 2010 | Intel Motherboard
Beeps after changing ram have removed new ram still just beeps
While not wanting to be a prophet of doom I do believe that you have killed your Motherboard.
Unless you get Ram which is a spot on match for the board one of the side effects can be a wipe out or corruption of the Bios.
You may be able to get support from Asus direct by clicking on the link below
http://support.asus.com/default.aspx?SLanguage=en-us
Jul 31, 2009 | ASUS A7V8X Motherboard
Display blanks and on board buzzer beeps
check your RAM >remove it > Cleen it > Fix it back> Try turning ur PC on again
Still no????
Check your VGA>remove>cleen>fix>switch on Pc
Still no?? use another RAM and try or a VGA....
3 beeps indicate...VGA problem
Conituous beep indicate....RAM problem
Apr 10, 2009 | Bernina Artista 180
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Dec 26, 2008 | HP Compaq d530 PC Desktop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
