Question about Toshiba (225EXTR5)
Replaceing the LCD SCREEN FOR THE TOSHIBA LAPTOP A*%_S!)&
How do I replace the LCD and what has to be done to take it off and changing it?
  • 1,800 Answers
Disconnect all the cables from the back
dvi cable+power cable that is and return them back to the new lcd
Posted on Aug 16, 2008
Broken Laptop Screen: Toshiba Satellite c670-165
As in this model?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/remove-replace-screen.htm
The Display Assembly is laid back to a point, that you can access the two bottom screws. Isn't a direct 90 degree position with the screwdriver. More like 60 degrees.
No?
Then the Top Cover (Palm Rest Cover) has to be removed, in order to access.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/remove-replace-lcd-screen-inverter-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Don't forget to remove ALL power. AC adapter and Battery.
Regards,
joecoolvette
Jan 13, 2013 | Toshiba Computers & Internet
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
Sometimes the Laptop works pretty good, but sometimes the screen blinks, and few others doesnt show anything. I took the laptop to a store, they say the circuits, lamp, cable are ok, but the LCD needs to...
Hi
If the LCD screen is blinking most of the tiem its an LCD problem and LCD needs to be replaced but ther are cases that it only needs a driver update from your video card. I recommend you do that first. Try to call Toshiba to check and give you the updated driver for your video card. If problem persists after updating the driver sadly you need to change your LCD as they suggested. Thanks
Feb 22, 2011 | Toshiba Satellite A215-S5837 Notebook
TOSHIBA SATELLITE M55-S3512 LAPTOP LCD SCREEN is red then it switches off. When I close and reopen the lid the screen turns on for 3 secondes then goes off. Do I need to change the lcd?
hi,
Please try to remove the battery and the AC adapter then press and hold the power button or the on/off button for one minute. Basically,it will not turn on since there is no power supply connected. After one minute, connect the laptop directly to the power outlet without using the battery just for the meantime then power on the laptop, if this will not fixed the problem, you will need to replaced the LCD cable or the LCD itself.
Hope this will help...
Jan 08, 2011 | Toshiba SATELLITE K000080220 LAPTOP LCD...
MY SCREEN IS BLACK BUT WITH A LIGHT I SAW MY STUFF IN MY SCREEN
The LCD of your laptop is disturbed. This is primarily due to some earthing problem or so. Once the backlight of the LCD is dim, it can't be repaired. You need t get the LCD replaced. It can be done at any Toshiba Customer Service Centre. If your notebook is covered by warranty, the replacement will be free of cost.
Feel free to ask anything else you want. I am following up.
Regards.
Dec 12, 2010 | Toshiba Satellite Pro L300 Notebook
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
A305-S6858 Laptop screen replacement
please reference follow steps to disassemble LCD screen
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/remove-replace-LCD-screen-inverter-1.htm
be careful all small cable like KB top cover LCD cable and inverter cable.
hope help you fix it, please take a rating let me know huw much helped you thanks! keep in touch your question.
May 21, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Computers & Internet Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
