Question about Epson Office Equipment & Supplies
Hello all my epson stylus cx3200 has a paper jam error note. I did all the things wanted by the printer including removing the paper , loading the paper etc but the red lamp is on again. someone told me the printer should be calibrated.I dont know how? what is calibrating? plz help me. Tnx so much
  • 31 Answers
HI,
It is the process for determination by measurement or comparison with standard.
pls follow these steps,
just you switch off the printer and once again connect,
place the paper correctly,and ensure there is no print jobs are in quaue
If so goto printer and faxes and select the default printer
and open it and cancel the tasks.you better select according the
page numbers that you want to print.try with this.
Posted on May 26, 2011
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
ERROR SAYS PAPER JAM
Its already a hardware issue. go to support.epson.com and look for a service center
Feb 01, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Dec 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
