Having trouble replacing the baffle plate in a heatcharm c600 wood heater.
2 Suggested Answers
SOURCE: Need an owners manual for heatcharm wood heater
I using a heat charmIV for the first time (just bought a house and it was already installed). Am baffled over fan knob- when to use/ switch off, and the 'high/Low' options?
At what stage do I use these 2 and for how long?
Michael
Posted on Sep 09, 2011
I need to put a new baffle plate in my 2100 coonara wood heater and cant find anything on internet bout how to do it
Try MFG website, or email their customer service. Also try the replacement part via Ebay. May have instructions with the plate.or do you already have the plate? If so go back to the seller and ask for the install instructions. (usually they come with the part)
Jun 13, 2015 | Cars & Trucks
Austwood wood heater cannot remove top baffle plate in the firebox
you dont remove it,you dont need to clean it besides tapping the creosoot off,it burns it off
Apr 03, 2014 | Heating & Cooling
Baffle plates
baffle plate for the flupipe or what..
Dec 16, 2013 | Pool & Spa
Random banging and whooshing sound
New water heater?
http://waterheatertimer.org/New-water-heater-making-noise.html
http://waterheatertimer.org/Repair-water-heater-valve.html
Water does not compress. So each faucet has air chamber located behind wall. Air chamber is usually just a vertical piece of pipe about 18" long with a cap so it never fills with water. When water flows... all the water back to the main supply begins to move toward the faucet. The weight of this water can be considerable. When faucet is turned off, the whole column of water suddenly stops, but weight of water is still pushing forward.
Without air chambers to cushion the sudden stop of water weight, the pipes bang and rattle. With air chambers, the weight of the water pushes up into the air chamber causing the air to compress, which silently cushions the weight of water, but also causes a push-back when water stops moving forward. The push back can then move water backwards where it compresses air inside another air chamber. So the water can slosh back and forth.
IF you have factory-installed heat traps on your water heater, these things have rubber baffles. The baffles hum and rattle and whistle and clog and cause strange sounds that carry through the pipes and water heater and wood joists etc. The water sloshing back and forth can move the baffles and cause noise.
Or maybe you have a check valve that has gotten loose.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you discover
May 17, 2013 | Water Heaters
Baffle plate has fallen to pieces in my parents hartford 80 wood fire. ??? how do ifix it or where to go for replacement.
This is not anything new as the parts in fire places burn out & need to be replaced Check with a fire place retailer who sells that type for spears .
Jun 12, 2012 | Cars & Trucks
Hayward H100 banging (superheating); replaced baffle, still superheating
I am having the same problem. the Baffle was loose so I attached it with a little gap at the top, then started shaking and pulsating but not as mush this time. Like you I'm not sure where exactly the baffle shoud be, or if there is something else that was damaged. Hopefully someone can chime in that had a successful repair. Or with any other thoughts.
Jan 09, 2012 | Hayward H-series Electronic Gas Pool...
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
Michael
May 24, 2010 | Heating & Cooling
REMOVING THE DASH ON A 1980 CAMARO SO I CAN REPLACE THE HEATER CORE
it is not ness to remove the dash.
Drain cooling system.
Remove inlet and outlet hoses from heater core.
Remove lower right hush panel.
Remove lower trim panel.
Remove heater case cover screws.
Remove heater case cover.
Remove core support plate baffle screws.
Remove heater core, support plate and baffle from car.
Reverse removal proceedure to install.
Refill cooling system and check for leaks.
Nov 08, 2009 | Chevrolet Camaro Cars & Trucks
Heating & Cooling Logo
358 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
