Question about Vacuums
We have an Ebac Homedry 660 dehumidifier. It makes a noise when started and the red light indicating water tank full comes on. It has been inspected by a local repair shop and we have been told that the 'Fan' is not working. The workshop does not know how to get a spare part. Who is the repair agent in Auckland, New Zealand?
SOURCE: Bissell 1698-1
the heater is blocked wih lime scale
Posted on Nov 13, 2007
LizDahl
  • 75 Answers
SOURCE: vacuum cleaner
What brand vacuum is it?
Posted on Feb 26, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover SteamVac Model F6056-900 SteamVac/SpinScrub.
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
Posted on May 26, 2008
  • 17 Answers
SOURCE: Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Posted on Jun 27, 2008
SOURCE: Red float keeps popping up
You need to clean the debris channel. Put the machine on a waist high flat surface open it and remove the dirty water container. You will see three vertical screws which lock the scroll above the motor to the clear plastic panel at the front of the machine. Open these screws and remember which one belongs where. To the left of the scroll, there is a black horizontal screw which should also be removed. If you look closely, you will see the right hand of the first three screws (brushes face to your right hand) has also released the plexiglass (clear plastic screen where you see the dirt and soap flowing at the left side. Now put the machine on its side and look at the front edge of the plexiglass just ahead of the brushes. There are two screws which have to be removed - one on each side and bingo the plexiglass shape lifts clear. Clean out the muck, check the scroll channel for similar muck and reassemble.
The muck is plugging the dirt path and fooling the red float that the tank is full.
Re assemble the reverse of the disassembly procedure. Do not use a power screwdriver as you will likely shear the screw heads.
Good luck,
AMSW
Posted on Dec 30, 2008
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Jun 28, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover SteamVac Model F6056-900 SteamVac/SpinScrub. Indicator light and high pitch suction noise indicates that dirty water tank is full. However, water level indicator (yellow bobbing plastic thing) is...
May 26, 2008 | Hoover Vacuums
Flow Indicator Not Moving, Not Dispensing Anything
The water tank and the solution tank both have red gaskets that attach to the bottoms of the tanks. Make sure they are on properly, I just had the same problem and spent hours taking apart the machine and inspecting lines to find out it was a gasket.
On my machine the red gasket for the solution got stuck in the chasis for the machine. The bissel website alludes to this, but isn't very clear.
Other posters talk about the heaters, or the lines being clogged and I immediatley inspected these areas, turns out it was a gasket that was hiding in the chasis. Both the water tank and the solution tank should have one, and make sure they don't get nestled in the chasis!
Apr 13, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vacuums Logo
123 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
