Question about M-Audio Studiophile BX5 Main / Stereo Speaker
Hi there, I have a pair of M audio BX5 speakers, one of them works fine, on the other hand, the other one sounds kindda funny. Both of the twitter and the 5-inch cone on it work, the main thing that's noticeable the most is the volume is a lot lower than the other one. I have switched the cables and the outputs back and forth a lot, but it didn't work. I use to be able to fix it just by turning the volume nob to the loudest and the volume will come back to normal in a bit, but now, this doesn't work anymore. I tried to match the level of the other speaker to this one to see if it's only the volume difference, but it turned out there are frequencies that are missing as well. Would you tell me what it is? Thank you so much. Wen
  • M-Audio Master
  • 2,918 Answers
Little goes wrong with a speaker unless it has either been overloaded or subject to damp, extreme dust or has sustained physical damage from some sort of accident.
A rough test is to move the speaker cone gently through most of it's travel using an even pressure simultaneously on various places around the cone, I use my fingers.
It should move smoothly without any resistance and most importantly it should be completely silent through the largest or smallest movements.
If it sounds scratchy, the speech coil is either off-centre or it has suffered damp or dust and dirt has ingressed into the air gap or the chassis has become distorted.
If it is silent and electrically sound it should produce normal volume.
There was a time when loudspeaker repair, overhaul or adjustment was routine but these days it isn't economic except for the highest quality and replacement is best.
After gaining access to the interior wiring of the speaker cabinet I suggest further testing it by wiring it direct and leaving out the crossover if it has one.
Posted on Mar 23, 2017
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: woofer not working on new bx8a speaker
Hi ermo
Your new speakers are BiAmped, and if a woofer is not working then it is probably a fault in the amp or connection for that woofer, or the the woofer itself has a problem. If they are brand new, I suggest you take it back to purchase point to get sorted out. There is nothing that you can do that will NOT void your warranty. If you do not have a warranty, then get back to me here and we can work through the problem. Cheers
regards
Graeme
Posted on May 25, 2008
esound
  • 425 Answers
SOURCE: I'm a video editor (MAC
Hi, cases like that always comes u. Earlier you said just replaced it, that's not too good for anew monitor speaker.
You could test the fuse inside the speaker if it's still working, might be power fluctuation that might have caused it to blow.but you need to test it. If it is the fuse,fine! you can replace it, it does not cost much to replace.
Also if i can recall,most new stuffs always comes with guarantee with it,right?. I would suggest you could take it back and get a replacement, and i guess if they see it,since it is on guarantee,they can fix it for you without even charging you a penny.
Hope that helped.
Thanks and feel free to pass on your comment.
Thanks for using fixya..
Posted on Jan 12, 2011
SOURCE: Hi, I have a pair
just check the wiring at the back of the cone its easily busted during the vibrations or you can multi tester to check the speaker
Posted on Mar 06, 2011
I'm a video editor (MAC OSX). I playback audio at fairly low volume. Recently, I turned on my speakers (BX5) and only the R came on. L was dead and inspection revealed it was "blown". Can't...
Hope that helped.
Jan 12, 2011 | M-Audio BX5a Speaker
Hello. I have a pair of BX5 monitors, purchased in May 2003. Both have been working fine until a few weeks ago. One just stopped working. I have checked the cords and they OK. Power to the monitor is...
This is power problem, the cable might be ok but power might not be getting to the panel to power on the monitor, i will advice you give the monitor to a local repairer to help diagnose the panel on your monitor, the power diode on the panel might be bad or burnt, and will need replacement.
This is the best option since you are not electronically inclined.
Take care.
Sep 14, 2010 | M-Audio Studiophile BX5 Main / Stereo...
Ac select REPAIR studiophile bx5
my speakdrs all of sudden started humming. Can't figure out what's wrong
Aug 19, 2010 | M-Audio Studiophile BX5 Main / Stereo...
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
M-Audio BX5 - No Power
Don't bin! This should be a simple fault to rectify.
Fault finding technique as follows:
Trace mains voltage up to main transformer - there could be a standby transformer with relay in parallel. Check mains voltage all the way until it stops. If you have voltage up to main transformer, check that you have low voltage at the other end - if not main transformer at fault. If you don't have, then check to see if you do have a standby transformer - much smaller and usually on small circuit board near where power comes in to speakers. They are notorious for blowing on many audio systems as they are constantly connected to mains unlike most of the other components - power spikes kill them in particular.
Jul 29, 2009 | M-Audio Studiophile BX5 Main / Stereo...
Bx5a monitor speakers
Check the capacitor, if its swollen or rusty it needs replacing, also check the fuse.
Jun 22, 2009 | M-Audio Studiophile BX5 Main / Stereo...
Light sound
Switch the speakers over just to make certain it's not the amp. If still bad on the good channel, then the crossover (inside) might have developed a fault.
Jan 25, 2009 | JBL E-30 Northridge E Series Bookshelf...
Sound from my Hanspree Xm-S monitor.
Sound like you need a audio switch. I have 2 of them, and both have worked great.
This is the one, I have, but they are very hard to get now.
http://tinyurl.com/279g23
This is a different one, but works ok. It just did not have the features like the first one.
http://tinyurl.com/ys2f9g
With the audio switch, or audio hub, as the first one is called. You can direct audio to your speakers or a pair of headphones.
I like the first one, because I can mute both, and the mic and adjust the volume. As I said more features. The second is just a toggle switch to send the audio signal to the speakers or the headphones.
Feb 23, 2008 | Hannspree HW191D LCD Monitor
Problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Oct 30, 2007 | Sony STR-DE545 Receiver
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Apr 14, 2017 | Paradigm Audio Players & Recorders
M-Audio Studiophile BX5 Main / Stereo Speaker Logo
51 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
