Question about InFocus Proxima DP6155 Multimedia Projector
I have a DP6150 and there is a purple line luminating down the right side of screen when in use. What is the cause?
Yea I have the same thing. I can't even see the screen to know where I'm going in the menu. I recently opened up my project to resolder some of the power points but I didn't touch the lens or lcd part.
Posted on Dec 10, 2009
How do I fix a Samsung un55c8000xfxza that has been through a fire? The TV still operates fine but the screen is dark on one side and has vertical lines on one side.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 30, 2016 | Samsung Televison & Video
Panasonic tv has black vertical line with thin blue, green, and purple lines within it on the right side. Can I replace a board or is the ribbon/tv panel shot?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Line fault to all LCD TVs; irrespective its brand and screen size is similar.
Nov 17, 2015 | Panasonic Televison & Video
Purple line running down screen
Hi! Try to uninstall and reinstall video driver in dev manager.If it doesnt work then check if it happens in bios if yes then it might be the video card that you need to replace, if video card is built in then you need to replace the motherboard.Try to use a external monitor and check if your seeing the same thing on the ext monitor if yes then its the monitor, if its under warranty your manufacturer will replace it for you.Hope this helps...
May 25, 2010 | Computers & Internet
The right vertical side of the projected picture seems to be slightly shadowed. Is this the lens or for some strange reason is the bulb going out? It only has about 200-300 hours of use on it
if you have the dp6150 (lcd projector), you have a lens or mirror out of alignment, or something obstructing the light from the inside. if you have a dlp projector (not the dp6150), the light tunnel has collapsed and needs to be replaced. you can get the part from an infocus service center (like av solutions in ny), or send it to them for repair. they're really good. www.avsolutionsny.com
Jan 12, 2010 | InFocus Proxima DP6150 Multimedia...
My InFocus Proxima DP6150 has images with red outlines shifted to one side. colors appear to be separated. Is there a way to fix this?
Service Code
The service code to enter the service menu is as follows:
` Press menu, then service, enters the following: Magnify Volume up, Volume down, Power, Menu, Source and enter.
Nov 25, 2009 | InFocus Proxima DP6150 Multimedia...
Real or Fake
check a bunch of things...even great fakes slip up on one or two details
check the luminous markers, are they painted well?
check the bezel luminous marker, does it match an authentic?
check the wing logo on the dial
look at the font for the date
look at the band pins (they should be screws-round or flat depending on model)
check the crystal, should have no reflection and a purple hue when viewed at an angle
under the lugs will be a date etched in to the case
the bezel will have a small "B" etched in between 11 and 12 on the side, not the face
Bottom line, unless you have paperwork in hand and a verification that the seller bought it from Breitling, you are probably looking at a fake
Oct 08, 2008 | Breitling Hercules 246/GRY/PROF
Purple-tinted transparent line
im thinking the set has a bad engine
Dec 18, 2007 | Samsung HL-R5678W 56" Television
Vertical line on TV
usualy this problem is cause by the lcd drive board.
Oct 09, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
InFocus Proxima DP6155 Multimedia Projector Logo
155 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
