Question about LG Televison & Video
My 50 inch lg plasma tv is flickering with no picture, we were watching it an u heard a click and then flickers with no picture.
  • marydraiseu May 28, 2011
    I have tried that, changed all nine capacitors but the picture still flickers have you got any other ideas thanks
    Genius:
  • 1,156 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.If otherwise,The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Take care in solving the problem....
Posted on May 26, 2011
  • Marydraisey May 26, 2011
    Thankyou very much for ur reply were waiting for the capacitors to come then we will try thankyou again we will let you know if it works.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Flickering problem with our LG Plasma 60 ps4 when connected to hd
I had a problem similar to that. I couldn't get a full picture from my laptop or desktop. I went into the menu and hit the adjust screen. Now I have a full picture on my 50" plasma tv.
sawrepairman
Jul 23, 2010 | LG 60PS60 60 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG Plasma TV
first i would try unplugging it for about 5 minutes to reset the set. after that i would need more detail as to the problem is there sparkles in the screen is it a certain portion of the set any info you can give
Jul 03, 2007 | LG 42PX4DR 42 in. Plasma TV
Televison & Video Logo
195 people viewed this question
Computer Repairing
Computer Repairing
